crosscutter55 Posted February 12, 2018 Share Posted February 12, 2018 what brand & size monitor do you guys like ? Link to comment Share on other sites More sharing options...
lbuttery Posted February 12, 2018 Share Posted February 12, 2018 I use a 37" tv/monitor set to 720P resolution it works great when clients come - no having to squeeze in shoulder to shoulder Lew Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 12, 2018 Share Posted February 12, 2018 See my signature Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 6:27 PM, Joe_Carrick said: See my signature Expand Mine too , but Benq has several newer Models out now including one with a built in KVM. The VA Panel models were Okay for me and not as pricey as the IPS models , which is good as I wanted to go Dual. M. Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 6:27 PM, Joe_Carrick said: See my signature Expand Joe what resolution do you have the 55" set at, I have a samsung 40" have no trouble with elevation view but floor plans suck on it when showing to clients Link to comment Share on other sites More sharing options...
Joe_Carrick Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 9:17 PM, chief58 said: Joe what resolution do you have the 55" set at, I have a samsung 40" have no trouble with elevation view but floor plans suck on it when showing to clients Expand I'll have to check when I get home. 1 Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 Thank you Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 9:17 PM, chief58 said: Joe what resolution do you have the 55" set at, I have a samsung 40" have no trouble with elevation view but floor plans suck on it when showing to clients Expand One of my 39" Samsung's had a PC Mode , it may help if you have it? but are you perhaps not using the TV's Native Resolution? ie 1920 x 1080 or ? I am assuming you mean the line work is all fuzzy? M. Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 M. my main monitor is where I have the floor plan on and it is duplicated to the larger samsung and that is where it doesn't look good just hard to see not fuzzy lines that I can see Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 On 2/12/2018 at 9:38 PM, Kbird1 said: One of my 39" Samsung's had a PC Mode , it may help if you have it? but are you perhaps not using the TV's Native Resolution? ie 1920 x 1080 or ? I am assuming you mean the line work is all fuzzy? M. Expand Ill have to check to see if it has a pc mode, know where is the paperwork for his mum Link to comment Share on other sites More sharing options...
Kbird1 Posted February 12, 2018 Share Posted February 12, 2018 Duplicating maybe the Issue as i think it will try to use the Main Monitor's resolution in that case , where as if you only use Monitor 2 it should use the Tv's Native Res. , been a while since I tried any of that stuff though... Most LCD are best veiwed at their Native Resolution though as they are optimised for it. Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 Mick my setup is 3 the 27" has Chief on it with my lib moved over onto the 24" and they when needed for clients I take the samsung tv and move it from hdmi 1 to hdmi 2 this is how I get the duplicted screen of the 27" monitor if that makes sense Link to comment Share on other sites More sharing options...
OkcDesigner Posted February 12, 2018 Share Posted February 12, 2018 When you duplicate screens they default to the lowest screen highest setting. IE if 1 is 4K and one is 1080, they will drop down to the 1080.... That along with other issues of different sizes causes different image quality, is why I have two identical.. TV / monitors, not as good as computer monitors but works for me after getting use to it. Clients love the ability to watch either screen...... Link to comment Share on other sites More sharing options...
chief58 Posted February 12, 2018 Share Posted February 12, 2018 Thanks for the explanation Marc guess I will just keep doing what I am doing until something other comes also Link to comment Share on other sites More sharing options...
