lavorhaynie
How to Draw an "odd" Roof Plane
I have an odd roof plane I need to draw. It is a simple triangle shape but each of the triangle points needs to be at a different elevation, making each edge non-parallel to the floor. It also make it difficult to determine the correct direction to draw the roof plane's baseline.  See attached pics.
Any ideas on how to draw a triangle roof plane like this would be greatly appreciated.
It would be nice if the "Change Roof Pitch or Height" dialog offered one more button to "Pivot About Selected Edge".
Thanks,
LaVor
Have you tried the Join Roof Planes tool ?  5a5daf8f87f2f_JoinRoofPlanestool.JPG.bd7e3f454adbe5dc84db571ae7a767fc.JPG
Or if that is what you are using and there is no way it will work, you can rotate the baseline in plan view or tilt it using the Baseline Angle: setting in the Roof Plane Specification DBX under the General Tab at the bottom.
Failing that, post the plan file and someone will have a look for you.
Yes. The planes do not join correctly because the needed orientation of the baseline is unknown and the needed roof pitch is also unknown.
I came up with a solution that uses CA geometry. It works perfectly and creates a roof plane that joins all edges correctly. Looks great!
If any are interested in the solution, leave a comment and I will create a video showing how I resolved this.
Best regards,
LaVor
I'd like to see. I normally adjust the baseline angle for planes like this, but it's always a guess as to the specific angle.
Posting your plan file will help others follow along too.
Thanks
Thanks,
LaVor
I'd be more inclined to draw/build it like this.
That roof plane can be set in place in the dbx. Post the plan please
Thanks,
LaVor
You can create 3 separate elevation points by using "baseline angle" as well in the roof plan dbx
That would be a great idea. Love to see what you did and how it worked out.
Yes please show us video on your method of repairing your roof plane.
I will get the video done sometime today or tomorrow. Things are hopping here with a bunch of plans in the queue. Builders waiting.
I hope this is an as built ;) and not new construction.
ct1.thumb.jpg.de0ce7ec730f5152aacb9557411cc681.jpgct2.thumb.jpg.97bbed0b9792f6c28c11ea47494574f2.jpg
Thanks for the video. Well thought out.
Don't know why but the camera view looked like it did not match the plan view. Like when you dragged the new roof plane down and to the right, in the camera view, it looked like it was going 90 degrees.
On 1/18/2018 at 0:01 PM, lavorhaynie said:
I finally took some time to create the video as promised.
Below is the plan I used in the video, (a partial plan with needed objects).
I have posted the video on youtube at https://youtu.be/AqT9pBODOMs
Happy Chiefing!
Roof Plane Issue.plan
Nice video Lavor : )  Thank you for bringing this up too.  This was a fabulous challenge that really peaked my interest and so I decided to make a video of my own with my take.  I would highly encourage anyone and everyone to watch this one.  I think there’s some pretty good stuff in here...
  • Upvote 2
Thanks for working that out Michael.  I figured it could be done.
    27461
    WaunakeeDesigner
    WaunakeeDesigner
  • Similar Content
    • By 9atatimer
      I'm using X11 premier on a mac -- I have an exterior garage wall (with a centered garage door) and a gable end -- I'd like to split the attic wall of the gable end into 3 parts -- the central region above the garage door, and the left and right, to have a different material above the garage door.
      I have Default Settings > Roof > Auto Rebuild Roof set to Off
      I have Default Settings > Framing > Automatically Build Floor and Ceiling Framing Off on all framing types.
      I have Default Settings > Walls > General Walls > Auto Rebuild Attic Walls set to Off
      If I delete the roof and ceiling planes with Build > Roof > Delete [X] and then use the Build > Roof > Build Roof ... dialog to rebuild the roof and attic from scratch -- I leave the Auto Rebuild Roofs set to Off, to be clear -- and then edit the resulting gable roof on the attic layer, I can split it twice to produce the three separate wall sections, but once I change the exterior material on any of the sections, the three wall segments get replaced with a single wall again.  The new wall has my selected material, but that does me no good as I need the distinct secgments.
      Anyone know what setting do I need to turn off to maintain the manually edited gable end?  Or is this a mac bug?
      Or, barring that, does anyone know what approach will let me give the desired finish detail (attached a pic of a freehand elevation)?
    • By blueriver
      I'm using Chief Architect Premier X11
      I have all these little 'X's can someone please tell me how to get rid of them?  I've been really playing around with the roof and i THINK they are from that but at the same time i have a couple random ones outside where the roof is -- i cannot get them to go away. Help!
      thanks in advance
      Lauren
    • By chief69
      Hello, We are having a hard time getting  the design program to do the roof right. We have tried with Sketchup and it got the closest. It's hard to describe I have attached a few pics with a decent idea of what we are trying to do.
      The Garage is a shed roof as well as the breeze way, but they are at different angles. The house is a butterfly style with the V running at a angle. WE do not care what the pitch ends up being on any of the roofs.
      Anyone know how to do this. I have been trying for hours and the program goes crazy every time. Esp with the all 3 roofs at different angles with each other. I have attached a copy of the plan we made and some pics from sketchup because that program got the closest to what we are trying to do.
      Thanks
      Chris
      New house v1.plan
    • By MN_JohnH
      I wonder why my second floor loft flooring is sticking through the roof and can be seen on the outside of the building?
    • By mprovost129
      Hi all. I'm fairly new to the software and have only been using it since October. I have a client who wants a wood framed chimney extruding from the middle of the roof up from the gas fireplace. I've tried a bunch of different options to make this work but can't figure it out. Can someone please tell me how to draw walls on top of the roof?
      Thank you!
