X9 ray trace and video
rispgiu
With Ray trace it is possible to
achieve a very good quality photo, it takes a while but that is beyond the point.
is it possible to create a walkthrough video with the same definition of a rendered Ray Trace image using Chief only?
Edited by rispgiu
Grammatical error
5 hours ago, rispgiu said:
Is it possible to create a walkthrough video with the same definition of a rendered Ray Trace image using Chief only?
I believe that the answer is yes but the time and computing power involved would make it impractical for the majority of clients to be able to afford unless there was a Hollywood budget available.  If you have lots of time or two or three high end Xeon workstations at your disposal it would be possible to use Chief's precision camera controls to produce thousands of high quality ray traces and stitch them together into a movie with editing software.
One of the guys did a short clip just in Movie Maker a while back using the zoom and pan features of the software and a few raytraces and it was quite effective, so depending on your level of perfection there are lots of choices when heading in this direction.
Also Chief did reveal some significant rendering improvements at the UGM this year for the upcoming version, so there is that to look forward to.
Thank you
Here it is:
You may also want to take a look at the possibilities of the new 360 deg. raytraces and maybe even screen capture video of several of those could be edited into a video if you are on a tight budget.
Don't forget to post your results if you come up with something good.
I'd definitely give it a try
