glennw Posted August 24, 2017 Share Posted August 24, 2017 I am trying to use a cad block that contains fill and I am losing the fill from the cad block. I have tried changing the CAD Blocks settings in the CAD panel of Preferences, but that doesn't help. Any ideas? The video explains the problem. Link to comment Share on other sites More sharing options...
JoeOster Posted August 25, 2017 Share Posted August 25, 2017 For whatever reason an electrical symbols 2-d cad block isn't capable of showing fill. I put lines very close together within the block to replicate a solid where needed. Link to comment Share on other sites More sharing options...
glennw Posted August 25, 2017 Author Share Posted August 25, 2017 Thanks Joe, That confirms my suspicion. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted August 25, 2017 Share Posted August 25, 2017 It seems to me that Chief has always been that way, but really should be fixed to show a fill Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 On 8/25/2017 at 4:12 PM, DRAWZILLA said: Chief has always been that way, but really should be fixed to show a fill Expand +1 Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 25, 2017 Share Posted August 25, 2017 This is only true for Electrical Symbols. If you check the "Duplex (Split Wired)" CAD Block you will find that even CA had to use lines for the fill. I created my own Electrical Panel Symbol with a XHatch to simulate the fill so it would look better in a wall. OTOH, CAD Blocks for other symbol types can have a Solid Fill and work fine. I think the difference is that the CAD Block for Electrical Symbols are symbolic rather than a 2D representation of the 3D Object. Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 Joe, How did you make the XHatch? Totally confused now as I have never had fill retained with a 2D Cad block used for a symbol. Just tried it on a fixture and would not work unless you want to use the symbol solid fill but that is a rather limited use. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted August 25, 2017 Share Posted August 25, 2017 You have to hatch a rectangle and then Block it. The rectangle has the hatch, not the block itself. Try this to see how CA does it. Place an ADA Toilet Symbol Go to CAD Block Management and Insert the CAD Block Explode that Block and examine the individual objects to see what has a fill. Of course, you have to have the "Fill Boxes Checked" in CAD Preferences. 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted August 25, 2017 Share Posted August 25, 2017 Ok Thanks Joe, That took a bit to figure out but I got it, There is a check box in the Symbol DBX, Symbol Specifications>2D Block>"Use Original Plan Colors" down at the bottom that becomes available after you select "Fill". Or just realized the if the cad block has solid fill already you can edit the color with the fill options. Unfortunately this is not an option for electrical symbols, so maybe I am still not understanding how you did your electrical panel if you built it as an electrical symbol ? At least I now have a blue ADA toilet. Link to comment Share on other sites More sharing options...
