jlcDesign Posted July 6, 2017 Share Posted July 6, 2017 Hey everyone. Does anyone have any words of wisdom for how to bend CA to our will regarding adding a floor system above an existing garage slab? Whether that be hanging a joist system on the wall and supporting with LVLs below, or even ripping sleepers and putting CDX over it? It's technically two floor systems. Am I explaining this right? I know I can do this with poly-lines, and maybe that's the answer. I figured one of you pointy-heads out there has already figured it out. Thanks a million! Link to comment Share on other sites More sharing options...
dshall Posted July 6, 2017 Share Posted July 6, 2017 20 minutes ago, jlcDesign said: Hey everyone. Does anyone have any words of wisdom for how to bend CA to our will regarding adding a floor system above an existing garage slab? Whether that be hanging a joist system on the wall and supporting with LVLs below, or even ripping sleepers and putting CDX over it? It's technically two floor systems. Am I explaining this right? I know I can do this with poly-lines, and maybe that's the answer. I figured one of you pointy-heads out there has already figured it out. Thanks a million! Yes, the sleepers should be part of THE FLOOR FINISH, not part of THE STRUCTURE. adding a floor is asking for trouble, Sorry Eric, A non-starter for me. think about it..... it is a FINISH. 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted July 6, 2017 Share Posted July 6, 2017 I've done it like Scott suggested by adding 3 layers to the Floor finish ...rigid foam, 2x6 joist (could be less or more) and 3/4" ply... 1 Link to comment Share on other sites More sharing options...
DRAWZILLA Posted July 6, 2017 Share Posted July 6, 2017 We typically pour a new slab over the existing garage floor slab and level with the house or curb. if it's a raised floor house, then I add new floor joists level with the house and piers for support. for slab floor you could just use the slab tool over the existing also. 1 Link to comment Share on other sites More sharing options...
dshall Posted July 7, 2017 Share Posted July 7, 2017 4 hours ago, DRAWZILLA said: We typically pour a new slab over the existing garage floor slab and level with the house or curb. if it's a raised floor house, then I add new floor joists level with the house and piers for support. for slab floor you could just use the slab tool over the existing also. Yeah, that works. I am working on a house with slab. 2 areas need to be raised, one by 6" the other by 12". I chose the sleeper method for this project. A slab for the 6" dropped area could work. Project in Solana Beach..... dld I ever say how much I hate working in Solana Beach? I do not think I will ever do another house in Solana Beach..... 1 Link to comment Share on other sites More sharing options...
lbuttery Posted July 7, 2017 Share Posted July 7, 2017 In real life we hung joists so that the new floor was even with the house floor so raised off slab by about 2' my goal was to have all floors inside the house at the same level so I could use a wheelchair or powerchair in the future if needed Lew Link to comment Share on other sites More sharing options...
jlcDesign Posted July 7, 2017 Author Share Posted July 7, 2017 Awesome stuff guys! Thanks for all the input. I like the thick floor idea. Link to comment Share on other sites More sharing options...
