kerone_12 Posted May 21, 2017 Share Posted May 21, 2017 Please look at images and try to assist me with this guys, i'm trying to add a balcony over a lower existing roof, but some how there is a hole in the floor slab of the upper floor which over hangs over the lower roof. Please see images attached. Using version X8 of Chief Architect Premier. Thanks Link to comment Share on other sites More sharing options...
justmejerry Posted May 21, 2017 Share Posted May 21, 2017 Post the plan. Could be lots of guesses without it. From the pictures I can tell you that your roof sloping towards that wall where balcony is, is not a good thing. Link to comment Share on other sites More sharing options...
kerone_12 Posted May 21, 2017 Author Share Posted May 21, 2017 Yes the roof is sloping towards the balcony, however the balcony is higher than the roof below Link to comment Share on other sites More sharing options...
glennw Posted May 21, 2017 Share Posted May 21, 2017 If you were building auto roofs, the Allow Low Roof Planes option is usually the setting to use. Otherwise, I would designate the upper floor patio to be either Open Below or uncheck Floor Under This Room. Then use a polysolid or slab and build the floor manually. Link to comment Share on other sites More sharing options...
kerone_12 Posted May 21, 2017 Author Share Posted May 21, 2017 On 5/21/2017 at 2:16 AM, glennw said: If you were building auto roofs, the Allow Low Roof Planes option is usually the setting to use. Otherwise, I would designate the upper floor patio to be either Open Below or uncheck Floor Under This Room. Then use a polysolid or slab and build the floor manually. Expand Thanks, i'm going to try it and get back to you. Link to comment Share on other sites More sharing options...
ShaneK Posted May 21, 2017 Share Posted May 21, 2017 Check floor thickness of balcony in framing dbx, make sure it matches your floor, or POST THE PLAN, lol. Link to comment Share on other sites More sharing options...
TLHomeDesigns Posted May 23, 2017 Share Posted May 23, 2017 This doesn't solve your problem but Either I'm just missing something or it looks like you going to have some major water trap issues with the gable coming down into that exterior wall. . Surely I'm just not seeing this right. Link to comment Share on other sites More sharing options...
johnny Posted May 23, 2017 Share Posted May 23, 2017 From the pictures this issue is related to design - not Chief. You dont want to simply fix the visual, you should look at the fundamentals you've got happening in that area. 1 Link to comment Share on other sites More sharing options...
RL-inc Posted May 23, 2017 Share Posted May 23, 2017 Gonna need a big cricket there or something. Link to comment Share on other sites More sharing options...
