Roof Creating Hole in Over-hang please help
kerone_12
Please look at images and try to assist me with this guys, i'm trying to add a balcony over a lower existing roof, but some how there is a hole in the floor slab of the upper floor which over hangs over the lower roof. Please see images attached. Using version X8 of Chief Architect Premier.
Thanks
If you were building auto roofs, the Allow Low Roof Planes option is usually the setting to use.
Otherwise, I would designate the upper floor patio to be either Open Below or uncheck Floor Under This Room.
Then use a polysolid or slab and build the floor manually.
Thanks, i'm going to try it and get back to you.
