360 Panoramic Ray trace vs. Render
CADD16
I have been experimenting with the 360 exports and all the Raytraces ones come out kind of blurry.  I've tried them at higher resolution and dpi but still not as clear as a render view.  Has anyone narrowed down the perfect setting for 360 Raytraces.  I have seen other topics with being discussed but no solid solution.
thanks
There's a mountain of discussion on this topic.
The overall consensus on fuzzy or grainey looking Raytraces is due to light bouncing off of either stainless steel or other shiny surfaces.
Reduce shiny surfaces and you'll reduce grainy appearance.
Polished materials/metals and predefined metals are definitely the most challenging. They rarely render properly when lit by standard point or spot light room fixtures. They seem to be highly sensitive to the angle and intensity of the light striking it's surface. What they seem to prefer is many light rays coming from many different angles, essentially highly scattered light. This type of light is more like ambient light which is different than the light from regular room fixtures. My philosophy is that lighting a scene is a layering process, the first layer being ambient which defines and controls the overall lighting of the scene and the appearance of the materials. On top of this layer you add additional light fixtures such as lamps and recessed lights to provide accent lighting. If the ambient lighting is not right you will likely struggle with the other lights. Unfortunately, the ambient controls do not seem to provide the right kind of ambient light, they seem to be more like a brightness control. Those invisible 3D lights are the ones to use, takes some experimentation to get a handle on them but I think the effort is well worth it.
Ya by Render I meant Chief's standard rendering views(not raytrace) When exporting a 360 Panoramic view with the standard render view the result is very clear.  When exporting a 360 Panoramic raytrace the result is a slightly blurry picture. The finished raytrace of a 360 before exporting looks fairly clear, but then through Chief's viewer it looks blurry.  My normal raytraces look pretty good but when using the same setting or even a higher resolution for the 360, it still comes out kind of blurry.  How do we get a similar result to the 360's done by Chief on their website?
I've tried increasing the resolution and the size of the image, but still looks kind of blurry.  When I do my normal Raytrace of the same space they turn out good
  • 1 year later...
