MicahPaul
In need of a Realistic Redering of my project
I have a set of plans that I have designed in Home Designer Architect.  I need a realistic rendering of these plans.  I believe this can be done by using a feature call Raytrace.  The feature is available on a much more expensive version of the software than what I have.  Would anyone with the Chief Architect software be willing to help me out.  Also how much would you charge for such a service? Thank you for your help.
MicahPaul
I would be happy to help you out. I do a lot of this type of thing (mostly for contractors using Chief) but occasionally for Home Designer users. Please email me with contact info and I will send you some samples and pricing.
 xxx@eartharts24.com
put my first name in place of the xxx (this is to help stop spam)
Joe King
MicahPaul
I offer rendering services as well, shoot me a pm
Nice render RENERABBITT,  i wonder if it would be even better if the "eye" was about 30" lower.....  in any case,  very nice.
How long did it take to render?
Curious if that was all done in CA?...meaning rendered in CA.
Thank you very much, I had the camera set to 6' tall but I think the focal point being wide angle makes it feel much taller, also had a heavy tilt down, I was trying to frame the carpet but I think you're right, made the scene feel a bit elongated.
this one took 17 hours primarily because of the wall paint being so many layers.
Modeled entirely in CA but rendered in Thea Studio 5
Thanks, I didn't think it was rendered in CA.  The lighting is just too good for it to have come from CA.
Here is a RT took 15 minutes. I am not an expert in this department, but I think Graham can produce that look in CA.
Nothing like putting on the pressure. Here is an example, not quite as refined but you can see the potential. This took 30 minutes to Ray trace and then about 5 minutes in a photo editor to fine tune the exposure, shadows & highlights and a bit of sharpening. I believe one of the major differences between Ray Trace and many of the other specialized rendering programs is that Ray Trace lacks in built-in photo adjustment/enhancement algorithms and as such this must be done separately. It's more like a Ray Trace is the equivalent of shooting RAW format with a digital camera.
I think that is a great job in chief - one of the better I've seen.  However, I still think the lighting on the other render is more realistic how it floods the space.  I've just never seen something done in Chief that I thought could be a real picture.
Here re are some Vray renders to compare.
Johhny those look great, but here is what I have got in 16 min using only chief. I am not saying chief is better and of course it can't be because those engines are primarily geared towards producing high quality realistic images.
But I am curious to know defects of this particular image.
when I look at floor and glass materials they seem to me what they should look like in real world, but I could be wrong.
Those a great renderings but it should be understood that those are not just a product of Vray. They have been extensively post processed in Photoshop and other image editors to obtain that look. They have also been produced by highly specialized/skilled graphics professionals. Your looking at the best of the best. it would be interesting to know how much time went into creating that, not only rendering time but the time it took to model such a complex scene.
31 minutes ago, TheKitchenAbode said:
......... it would be interesting to know how much time went into creating that, not only rendering time but the time it took to model such a complex scene.
That is the question.....
I dont think it took the post rendering work you may think.  Sure, its been that way in the past, and people still make adjustments after a render but I dont think its what seperates Chief's render engine and Vrays.
Here is a video showing a model/render and you can see the render portion took a fraction of the overall time (towards end of video).  The results he got were well beyond what Chief could do.  Note: 52:51 in the video starts render.
I setup a similar scene to show some difference in quality from Thea to Chief, Note I missed a few details(including forgetting to change the cabinet texture to something with better settings)
Overall time in Thea was 20 minutes to setup lights and materials
18 min render
I could've gone into more detail with materials and render settings to get a more realistic shot, which would've taken a few more hours of setup and 5-10 hours of render time, but for the comparison I thought this would suffice
Which one is which of the 2 stacked photos? Is the top one Thea and the bottom one Chief or the other way around? And the very top one is Raytrace?
of the two, the top one is THEA, and the bottom is the rendering that HUMBLE CHIEF posted using Chiefs built in Ray Trace
I was looking at the Thea products... does anyone know which one works best with CA models?
Made some lighting adjustments to improve the effect of light coming in from the exterior. This is a Ray Trace from CA with some minor adjustments for saturation and sharpness. All lighting is done with spot lights. The sun was turned off as well as the environmental lighting and spot lights were used to create the exterior lighting effect.
On 5/29/2017 at 3:21 AM, johnny said:
Great Vray renders, always good to see two-point perspectives. (observable with the straight vertical lines)
We used to have the 2-point until version 8 came. The solution is to hit the letter P as soon as you made the view.
I have to agree.
From the point of real estate photography, it is more pleasing to the eye if the walls are vertical which requires that the camera be level (not looking up or down) so sometimes you need to raise or lower the eye ht to get the look.  Give it a try and see what you think.
I have learned more about how to compose a 3d rendering from photographers then render pros.   You can watch the whole 10 minute video and see before and afters of great real estate photos but there is a mention of the distortion at 4:02 in the video. (this can be adjusted to a point before you render or just use Photoshop to correct the final image.
Take note that in the second video, the camera is about 45" AF.
Thanks for sharing, WesternDesign
MicahPaul
Hi Micah, I would love to send you over our works. Please see attached for my brochure. I charge on the hour @ $25 per hour or a lumpsum depending on the size.
Final Chief Architect.pdf
    28141
    kepine
    kepine
  • Similar Content
    • By pgjacob
      Hi All
      I am trying to render pool water.  I have tried different things but I just can't seem to get it to look right.  The first two supplied are from "pool Studio".  To me these look fairly realistic.  I like the transparency and color.  The last two are my renderings.  I know it has a lot to do with the pool plaster material, texture, etc.  But I just can't seem to get a good pool water.  I have gone to the Sketch Up Club for good images.  Just looking for tricks and tips as I have been doing alot of pools lately..
      thanks in advance
      melissa
    • By marie-eve
      I have a MacBook Pro but can’t use my ex10 version on it it crash all the time, I would like to buy a new laptop for version x12 any suggestion for a long road ?
      I know the MacBook Pro next generation will be out of only next year...
    • By kingsgate
      Hello,
      I have the HTC vive, steam set up and am able to tour my projects, but it renders with weird flashes of black, sometimes a rainbow effect, usually fairly blurry. I have all lights, shadows and reflections turned off. Any suggetions on how to fix this?
    • By Renerabbitt
      Open to new work. I've been working remotely for clients for years and can easily navigate the issues that present themselves from remote work. I have plenty of references and videos demonstrating my various services. The following images are snippets from my site at www.RabbittDesign.net
      I offer training-while-drafting services in Chief Architect as well as training in Sketchup, Thea Render, Photoshop, Premiere Pro and Procreate.
      I tend to cater to experienced designers and drafters in Chief Architect, many of which benefit from and are quite pleased with anno/layer sets, library items, toolbars, and a more cohesive folder structure and .plan and .layout files.
      A few hours of my service may cut hours off of every project you have going forward.
      Feel free to check out my YouTube channel dedicated to all things drafting, designing, modeling and rendering in my signature below.
      Take a look at some of my recent design work in the Gallery
      Also, take a look at the extensive Free Content Thread and continued free content YouTube Series:
    • By chrisped
      I have a home design that I am working on in home designer professional 2020.  Would eventually like to get it completed and then a set of construction prints for Nashville, Tennessee.  whidh means I will need floor plans and elevation views as well as a plot plan.  I have the plot drawn with some contour lines in the drawing I have developed.  The house faces about due west (not the best but that is the lot I have.    I have attached a picture of what I want the exterior rendering to look like.  Looking for job bid.  The plan file is zipped and attached.  Following needs to get done and then a front rendering and the file returned with the updates.  (Can pay via paypal etc)
      1. Master bedroom vaulted ceiling following rafters up to height of 12 feet then flat across.  House rafters will be 2x8 or 2x6 depending on span.
      2. Fix the roof planes
      3. Shed roof with 2 in 12 slope over the back deck.  Extends out about even with the master.  This is asphalt shingles.  Ceiling will follow the rafters
      4. The peaks (side and front larger dormer) should be board and batten not sided, the rest of the house sided, the foundation walls are stone
      5. Make sure chimney carries through to the roof from fireplace in family room.  Chimney is stone where it can be seen outside of house.
      6. The basement foundation walls connecting to the crawl space (unfinished area) should be only 5' tall (it would just be in one area)
      7. Front porch is to have a metal roof, rest of house is asphalt shingles (charcoal color but not black)
      8. Stairs should be 42" wide and should be fixed . Want them closed underneath. Somehow I cant get this to look right
      9. Need a front rendering showing view of the house for presentation to client
      10. Need file updated to reflect these changes and has to be readable with Home Designer Pro 2020
      11. Floor deck for both the first and second floor are 11-7/8 TJI with 3/4 subfloor (I think I have this right).
      At any rate, looking for quote to get this done.  Thanks for looking.
      House Design Front Walkout.zip
