Radius dimension
RobWhite
  • 2 years later...
I'm guessing the radius and diameter dimension is still not an option on X10?  Will it be there on X11?  Shouldn't this have always been a standard thing in dimensioning?  I can fudge a circle dim., but how many actual circles do we build?  I need to dim many arcs..  Any shortcut ways to dim. a center of a arc?  I can see the point when I pick the arc, but not in dim mode.  Back to the drawing board and locate centers with cad lines is the only way I can think.
Point to point dimensions will locate and snap to the arc center.
If you toggle on "Arc Centres and Ends", you can snap an End to End dimension from the centre point to the arc/circle.
Make sure you have at least Centre snaps toggled on and start your dimension on the centre point.
  • 7 months later...
