VistaGroup Posted December 29, 2016 Share Posted December 29, 2016 I'm fairly new to chief architect.....I have a design I'm working on and I can't figure out how to get a gable roof over the front porch.....I've tried everything. Can someone point me in the right direction? Link to comment Share on other sites More sharing options...
BrownTiger Posted December 29, 2016 Share Posted December 29, 2016 Probably post a design. Can't really tell what you are trying to do. 1) Are you trying to have a floor with a gable over front porch? 2) Shed roof [half gable front porch] 3) Shed roof on outside, gable on inside opened gable looking end 4) Gable porch Link to comment Share on other sites More sharing options...
joey_martin Posted December 29, 2016 Share Posted December 29, 2016 Select the front wall, open the DBX, go to the roof tab, and select gable. Link to comment Share on other sites More sharing options...
parkwest Posted December 29, 2016 Share Posted December 29, 2016 Have you tried clicking on the wall you want the gable on and then clicking on the little house with the pointy red roof icon located on the edit bar? Link to comment Share on other sites More sharing options...
VistaGroup Posted December 29, 2016 Author Share Posted December 29, 2016 Sorry guys. My name is Scott and it's premier X8..... it's a standard front porch....elevated off the ground about 4 ft. I tried clicking the wall and then making it a gable and then Auto rebuilding the roof.....that didn't work. The porch is literally like a deck off the front of the house. 8ft out 38 ft long. It's not going to be a screened in porch or anything like that just a front porch that has a roof over it that also adds an architectural appeal to the house. Link to comment Share on other sites More sharing options...
MPDesign Posted December 29, 2016 Share Posted December 29, 2016 Shift select all your walls of the Porch, open dbx and uncheck no locate under the general tab. then your roof commands will work. Link to comment Share on other sites More sharing options...
joey_martin Posted December 29, 2016 Share Posted December 29, 2016 If you drew the walls with the deck rails tool, make sure that you have selected to have a ceiling/roof over the deck. Link to comment Share on other sites More sharing options...
VistaGroup Posted December 29, 2016 Author Share Posted December 29, 2016 Dbx? Link to comment Share on other sites More sharing options...
VistaGroup Posted December 29, 2016 Author Share Posted December 29, 2016 10 hours ago, parkwest said: Have you tried clicking on the wall you want the gable on and then clicking on the little house with the pointy red roof icon located on the edit bar? Yes that didn't work Link to comment Share on other sites More sharing options...
VistaGroup Posted December 29, 2016 Author Share Posted December 29, 2016 24 minutes ago, joey_martin said: If you drew the walls with the deck rails tool, make sure that you have selected to have a ceiling/roof over the deck. I didn't use the deck rails tool..... I drew the deck and railing then added walls on top of the deck and adjusted the height of them so that they are only 10 in tall......should I be using a different format? Are there any other videos or tutorials I can watch to better understand this program? I've watched everything I can find. Link to comment Share on other sites More sharing options...
javatom Posted December 29, 2016 Share Posted December 29, 2016 Make sure your room dbx says "deck" and is marked to have a roof over it. Link to comment Share on other sites More sharing options...
joey_martin Posted December 29, 2016 Share Posted December 29, 2016 2 hours ago, VistaGroup said: I didn't use the deck rails tool..... I drew the deck and railing then added walls on top of the deck and adjusted the height of them so that they are only 10 in tall......should I be using a different format? Are there any other videos or tutorials I can watch to better understand this program? I've watched everything I can find. Yes. Just use the deck rail tool and tell Chief you want a ceiling and roof over it...poof, done. Just a couple clicks. Link to comment Share on other sites More sharing options...
DMDesigns Posted December 29, 2016 Share Posted December 29, 2016 I have a FREE training video showing you how to do that http://www.chieftutor.net/the-basics-free.html About half way down that age -Dave Link to comment Share on other sites More sharing options...
VistaGroup Posted December 29, 2016 Author Share Posted December 29, 2016 (edited) Success! I didn't label it as a front porch....once I did that I just checked the right boxes and poof....a roof appeared! And the videos helped so much! Thank all of you again. I'm sure I'll have more questions in the future. I should clarify that I had it labeled as a deck originally once I changed it to porch boom all the options I needed were there. Edited December 29, 2016 by VistaGroup Link to comment Share on other sites More sharing options...
