BrownTiger Posted December 14, 2016 Share Posted December 14, 2016 anyone has a symbol for that? http://www.homedepot.com/p/MUSTEE-Utilatub-24-in-x-20-in-Structural-Thermoplastic-Wall-Mount-Utility-Tub-in-White-19W/202041459 Link to comment Share on other sites More sharing options...
joey_martin Posted December 14, 2016 Share Posted December 14, 2016 Perhaps here.... https://3dwarehouse.sketchup.com/model.html?id=bc224120-5de4-4d2c-b431-b4d97a529060 ...make needed adjustments and save? 1 Link to comment Share on other sites More sharing options...
Chopsaw Posted December 14, 2016 Share Posted December 14, 2016 CA Core Catalog. Single Basin Laundry Sink. Link to comment Share on other sites More sharing options...
Kenoeightspot Posted December 14, 2016 Share Posted December 14, 2016 Here is the Utility sink from CA. Lib. that I modified with out the legs. Add to your lib. UTILITY SINK WALL MOUNTED.plan 1 Link to comment Share on other sites More sharing options...
BrownTiger Posted December 15, 2016 Author Share Posted December 15, 2016 Thank you, everyone Final product. I did use the sketchup model and added missing wings on the back that go against the wall. One thing I did NOT realized that CA does not SUPPORT 17.0.1899 sketchup, or anything 17 for that matter. [likely have came out after the current version of CA] WallLaundrySink.calibz Link to comment Share on other sites More sharing options...
Ridge_Runner Posted December 16, 2016 Share Posted December 16, 2016 5 hours ago, BrownTiger said: One thing I did NOT realized that CA does not SUPPORT 17.0.1899 sketchup, or anything 17 for that matter. [likely have came out after the current version of CA] You probably know BT but you can always save down to other versions of SU. I usually go down to version 8 for symbols. Mike Link to comment Share on other sites More sharing options...
BrownTiger Posted December 16, 2016 Author Share Posted December 16, 2016 25 minutes ago, Ridge_Runner said: You probably know BT but you can always save down to other versions of SU. I usually go down to version 8 for symbols. Mike That would be correct. Stupid me, first I went in and changed the binary version # inside of skp file, I got an error from Sketchup stating that version 15.1.331 can not open 14.1.xxx files Please upgrade. What?! So I went to sketchup and saved it as V15 and had no issues with CA opening it up. Link to comment Share on other sites More sharing options...
