GeneDavis Posted November 17, 2016 Share Posted November 17, 2016 This is a new thread to discuss what was embedded in the previous thread about stretch planes and zones. In that topic, a Chiefer had taken a symbol, resized it to about 50 percent of original, and then wished to set a stretch plane for using it above a counter. I found it impossible to do because I could not figure out how to export the resized symbol. Try it with any pendant light in the Chief libraries. Take the symbol, let's say it is 20 x 20 inches x 40 inches high, resize it maintaining its aspect ratio to 10 x 10 x whatever, and try resetting a stretch plane so its stem will stretch. Would not work for me. You can succeed with the symbol at original size, but not after resizing. So how do you export one that has been resized, and then turn around and import it back so Chief now has a fresh look at it? Link to comment Share on other sites More sharing options...
rlackore Posted November 17, 2016 Share Posted November 17, 2016 Gene, why doesn't the method I demonstrated in the original thread work? 1. Set the size using the Object Specification dbx. 2. Save as symbol and set up the stretch planes. 3. Done. 1 Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 17, 2016 Share Posted November 17, 2016 If you want to give Chief a "fresh look at it" you'll need to take a 3D view and Convert To Symbol. Now all the old sizing info is gone and you can start again with your new version. You may just need to assign a new CAD Block. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 17, 2016 Author Share Posted November 17, 2016 Show us how to "save as symbol." Thanks. Link to comment Share on other sites More sharing options...
rlackore Posted November 17, 2016 Share Posted November 17, 2016 Start a new plan, insert the old symbol, re-size it, then Tools>Symbol>Convert to Symbol. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 17, 2016 Share Posted November 17, 2016 3 minutes ago, GeneDavis said: Show us how to "save as symbol." Thanks. You can just "Add to Library" after making the appropriate edits. Then delete the old version from the Library. 1 Link to comment Share on other sites More sharing options...
rlackore Posted November 17, 2016 Share Posted November 17, 2016 22 minutes ago, Joe_Carrick said: You can just "Add to Library" after making the appropriate edits. Then delete the old version from the Library. Heck, it's even easier than I knew. A point for Joe. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 17, 2016 Author Share Posted November 17, 2016 Do it with this one. The attached file has the infamous "barn pendant" symbol, in its resized form. The goal is to put a stretch plane in the downrod so it can be lowered. I saved it to Library and brought it in, but it still acts wrong. BarnPendantResized.plan Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 17, 2016 Share Posted November 17, 2016 32 minutes ago, GeneDavis said: Do it with this one. The attached file has the infamous "barn pendant" symbol, in its resized form. The goal is to put a stretch plane in the downrod so it can be lowered. I saved it to Library and brought it in, but it still acts wrong. BarnPendantResized.plan Gene, Since this fixture is resized, you will need to display the original in a blank plan, resize and "Convert to Symbol" in order to get it to perform properly. Link to comment Share on other sites More sharing options...
MarkMc Posted November 17, 2016 Share Posted November 17, 2016 Putting a resized symbol in the library doesn't work-it retains all the original symbols default information. Open the symbol from the plan and look at the bounding boxes-then check one added to the library and look at those. Both are the same. The only way to change the default symbol information is to create a new symbol. The only way I know to do that is to open a new plan, place the symbol there, 3d view, convert to symbol. Here is the dbx of the new symbol. I do this all the time-need a leg for an island where the location of flats and turnings change- I may go through 4 generations of make new symbol, change stretch zone, resize, make new symbol, etc. Link to comment Share on other sites More sharing options...
GeneDavis Posted November 17, 2016 Author Share Posted November 17, 2016 And that is the answer, Mark. But let me clarify for our readers, particularly the Chiefer that got this started in an earlier thread. You must save the resized symbol to the library. You must then open a new Chief file, and place the symbol you created and put in the library, placing it into 3D space. That means there are no walls, no floors, nothing in 3D space except this symbol. Now go to File>Export>Export 3D Model (STL, ) and send it off. This is what is meant by convert to symbol. Now, in a Chief file, doesn't matter if you have walls, etc., IMPORT that file as a symbol, be sure to make it an Electrical type, and import it. One can now make whatever adjustments in the Symbol dialog to place a stretch plane, and have it operate as one wants. Note in the attachment, I have already stretched it after placement and locating a stretch plane at z = -9". The shade and canopy have not stretched, only the downrod. Link to comment Share on other sites More sharing options...
MarkMc Posted November 17, 2016 Share Posted November 17, 2016 Exactly Gene- well almost. You must use a new plan but you can copy from the first plan instead of placing in the library. IF I have to go through a few generations of resize in different directions then I naturally each new symbol goes into the library. Also you can have walls and such in the new plan BUT if you do you have to turn ALL of those layers off in the 3d view before making converting to symbol. When building symbols with solids, plines and whatever other junk I often find it easier to have a wall to reference and a floor to reference to with back clipped section views. Link to comment Share on other sites More sharing options...
