Chopsaw Posted October 29, 2016 Share Posted October 29, 2016 I have a high resolution image that I was using for a material but now something has changed and in standard view it tiles itself even when set to "Stretch to Fit". I thought maybe a setting was changed or my library was corrupted, but the twist is that it displays properly when Ray traced and tiled in Standard view in preview as well as when applied in the plan. It is a 500 dpi.png file. Any Suggestions. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted October 31, 2016 Share Posted October 31, 2016 post the plan.....;o) or at least the material..... Link to comment Share on other sites More sharing options...
Chopsaw Posted October 31, 2016 Author Share Posted October 31, 2016 Thanks Dennis, I am going to talk to tech today but if they can't help I will try posting a stripped version to see if you can help figure this out. Link to comment Share on other sites More sharing options...
jcaffee Posted October 31, 2016 Share Posted October 31, 2016 What's your expected output that 500dpi is needed? 300dpi is tops for most high quality digital output. If your output is to screen, then 72dpi. Or, if you're sending to Layout for inclusion into CDs, then either 72 or 150dpi should do the trick. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted October 31, 2016 Share Posted October 31, 2016 I use 650 for printed plans Link to comment Share on other sites More sharing options...
Chopsaw Posted November 1, 2016 Author Share Posted November 1, 2016 Ok, Thanks for showing and interest and here is the generic test plan in X8. This is a project that tech support myself and a couple of other forum users are working on and we were making some progress and then everything fell apart on me a few days ago and will not work now. The high resolution material file tiles when set to "Stretch to fit" ??? I can get it to work at much lower resolutions but that defeats the purpose of the project. Image 1 is what you should see in plan view and then Image 2 is what I am seeing in Perspective Full Overview. If you see something better or different please let me know and maybe we can figure out what is going on. If this barrier can be broken this process opens many possibilities of using text, cad, and dimensions in 3D views. Please do not open this plan file unless you have plenty of experience crashing chief architect and know how to use Task Manager to End Task. Oh and it might be helpful to have a computer and video card setup that matches or out preforms my specs. Who knows? Bush Lot Test.zip Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 1, 2016 Share Posted November 1, 2016 Hey Chop. It seems to be working just fine for me... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 1, 2016 Author Share Posted November 1, 2016 Michael, What did you do??? How much memory does your video card have/desktop or laptop? And thanks for taking a look. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 1, 2016 Share Posted November 1, 2016 Michael, What did you do??? How much memory does your video card have? And thanks for taking a look. I didn't do anything. Just opened the plan, copied the texture to a non-zipped folder, created a 3D view, reassigned the material, and that's what I got. Maybe the image was downsized during the zipping process? Here's what I get for the image properties... Link to comment Share on other sites More sharing options...
Chopsaw Posted November 1, 2016 Author Share Posted November 1, 2016 Image properties match the original. Still confused. Even the Teapot does not work. Did you do that on your desktop with a 1 GB GT430 putting my system to shame? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted November 1, 2016 Share Posted November 1, 2016 Image properties match the original. Still confused. Even the Teapot does not work. Did you do that on your desktop with a 1 GB GT430 putting my system to shame? Yes I did. I do have an SSD that really speeds things up for me, but not so sure that would have any affect on this particular situation though. Link to comment Share on other sites More sharing options...
jcaffee Posted November 1, 2016 Share Posted November 1, 2016 Works fine on my end--using OLD laptop hardware. See if AMD has any driver updates? Link to comment Share on other sites More sharing options...
Chopsaw Posted November 1, 2016 Author Share Posted November 1, 2016 Thanks Jon, I was just offline fooling around with drivers and rolled back 2 versions and restored some functionality on the plan I was working on for my client but now it will not even open the Perspective Overview on the posted test plan. Frustrating situation to be in. Looks like I will spend tomorrow trying to find a driver that works. Is that GTX 560M of yours a 1.5GB card? Can you see now why I am trying to get the higher resolution so that I can zoom in on the details? Link to comment Share on other sites More sharing options...
jcaffee Posted November 1, 2016 Share Posted November 1, 2016 No, it's a 3GB card. Good luck! Link to comment Share on other sites More sharing options...
rlackore Posted November 1, 2016 Share Posted November 1, 2016 Also works fine for me. Link to comment Share on other sites More sharing options...
DRAWZILLA Posted November 1, 2016 Share Posted November 1, 2016 Looks like your video card has 2gb of memory which is a little shy of what you should have, throw a 1000 series NVidia card ( they are very good prices right now)in there, and you will see it working like you have never seen. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2016 Author Share Posted December 1, 2016 On 10/31/2016 at 11:57 PM, Alaskan_Son said: Hey Chop. It seems to be working just fine for me... Michael, Still struggling to figure this one out and tech has be unable to help so far. If you have a minute do you mind sharing your Render settings so I can compare and see if they might be a factor in this situation. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 1, 2016 Share Posted December 1, 2016 33 minutes ago, Chopsaw said: Michael, Still struggling to figure this one out and tech has be unable to help so far. If you have a minute do you mind sharing your Render settings so I can compare and see if they might be a factor in this situation. I have everything set the exact same as you do with the exception of the walk through codec. That shouldn't matter though. Maybe try deleting that texture and downloading the version you attached. Like I said earlier, maybe something changed during the zipping process...just an idea. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2016 Author Share Posted December 1, 2016 Ok Thanks, I will give that a try just in case, since I think I have tried almost everything else except for Perry's suggestion. $$ So you are not a walkthrough guy then without Xvid installed. In Alaska it can be used as a walkaround or even a flyby since you all seem to be outdoor people. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted December 1, 2016 Share Posted December 1, 2016 2 minutes ago, Chopsaw said: Ok Thanks, I will give that a try just in case, since I think I have tried almost everything else except for Perry's suggestion. $$ So you are not a walkthrough guy then without Xvid installed. In Alaska it can be used as a walkaround or even a flyby since you all seem to be outdoor people. Ya, I think in all the years I've been using Chief I only ever made one walk-through and that was just for kicks. I don't personally find them all that useful. That's just me though. I find still images allow me a lot more control...especially when trying to narrow the focus to a specific item or idea like I'm usually wanting to do with most of my renderings. Link to comment Share on other sites More sharing options...
Chopsaw Posted December 1, 2016 Author Share Posted December 1, 2016 24 minutes ago, Alaskan_Son said: Maybe try deleting that texture and downloading the version you attached. Like I said earlier, maybe something changed during the zipping process...just an idea. I had high hopes but ended up crashing Chief just trying to put that file into the Library as a material with this current video driver that I rolled back to. On 11/1/2016 at 4:33 AM, Chopsaw said: rolled back 2 versions and restored some functionality on the plan I was working on for my client but now it will not even open the Perspective Overview on the posted test plan. Frustrating situation to be in. Hoping that AMD or CA will come up with a solution for me soon. Link to comment Share on other sites More sharing options...
