capitaldesigns Posted October 2, 2016 Share Posted October 2, 2016 Below the room labels Chief has a string of text showing the room size. Is there a way to have Chief show the rooms ceiling height instead of the rooms dimensions ? Thanks, Mike Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 2, 2016 Share Posted October 2, 2016 You also need to turn off the Layer "Rooms, Dimensions" and in the Default Room Label insert the macro as Eric pointed out on the 2nd line of the Room Label. You can also enter " Clg.Ht. " either before or after that macro. Note: If you want to control the text size to be smaller than the Room name you will need to do it all in a Rich Text Box. Link to comment Share on other sites More sharing options...
capitaldesigns Posted October 3, 2016 Author Share Posted October 3, 2016 Thanks Eric & Joe. Joe, are you saying that I should type in the macro command for the clg. ht. in rich text box first, set the text height there then copy and paste into room label default box ? Another question. Where do I set the room label text size & style Thanks, Mike Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 3, 2016 Share Posted October 3, 2016 No, When using a Rich Text Box, you can place the %room.name% macro on line 1 and the %room.height.ceiling% macro and any other text you want on line 2. You can set the formatting of each line (Font, Color, Size, Justification) and the border and fill for the entire RTB. Copy/paste that RTB into each Room. You can even place it outside the room and add a leader line with arrow to connect it to the room. Make sure you turn off the Room Label Layer. You've created your own custom Room Label. Link to comment Share on other sites More sharing options...
capitaldesigns Posted October 3, 2016 Author Share Posted October 3, 2016 Now that is cool. Thank you Joe. Mike Link to comment Share on other sites More sharing options...
glennw Posted October 3, 2016 Share Posted October 3, 2016 No, When using a Rich Text Box, you can place the %room.name% macro on line 1. No need to do that, just leave a blank line and chief will auto insert the room name. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted October 3, 2016 Share Posted October 3, 2016 No need to do that, just leave a blank line and chief will auto insert the room name. But you can't format the blank line Link to comment Share on other sites More sharing options...
Kduke11 Posted October 28, 2016 Share Posted October 28, 2016 How can you get this to show in feet and inches? But you can't format the blank line Link to comment Share on other sites More sharing options...
OkcDesigner Posted October 28, 2016 Share Posted October 28, 2016 How can you get this to show in feet and inches? Beg CA, like the rest of use!!! Or type it in, each room. Joe has a great macro to change inches to feet and inches, in the label method. Will not work on Rich Text Box....... Link to comment Share on other sites More sharing options...
Kduke11 Posted October 29, 2016 Share Posted October 29, 2016 Beg CA, like the rest of use!!! Or type it in, each room. Joe has a great macro to change inches to feet and inches, in the label method. Will not work on Rich Text Box....... We signed up for his and I have some but very new to the Macro's in CA. have written LISP's for AutoCAD. I'm fine with it in the room Label. LOL Link to comment Share on other sites More sharing options...
Alaskan_Son Posted October 29, 2016 Share Posted October 29, 2016 You can always put just the ceiling height in the room label and the rest in a Rich Text box. You would just have to manually align the 2 labels. Link to comment Share on other sites More sharing options...
