Migaloo Posted April 9, 2016 Share Posted April 9, 2016 Anyone know why my reference floor display would show walls in black instead of red? Everything in the reference floor display options is set to display in red but the walls display in black on this particular plan. Link to comment Share on other sites More sharing options...
BrownTiger Posted April 9, 2016 Share Posted April 9, 2016 You can set referenced color - to whatever color you want. Without a plan it is impossible to tell what you did... see here https://www.chiefarchitect.com/support/article/KB-00216/modifying-the-color-of-the-reference-floor-lines.html Link to comment Share on other sites More sharing options...
Migaloo Posted April 9, 2016 Author Share Posted April 9, 2016 yes everything in the reference display options is set to red. Link to comment Share on other sites More sharing options...
Migaloo Posted April 9, 2016 Author Share Posted April 9, 2016 The doors, windows and stairs all display in red like they should. The walls display in black but are set to display in red. Apparently something is overriding this setting. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 There's a really good chance you'll get an answer if you post the plan. Link to comment Share on other sites More sharing options...
Migaloo Posted April 9, 2016 Author Share Posted April 9, 2016 I have tried to upload but the file is too big to upload. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 You can email it to me if you'd like and I'll take a peek. I'll send you a PM with my email address. Or you can send to Dropbox. Link to comment Share on other sites More sharing options...
Migaloo Posted April 9, 2016 Author Share Posted April 9, 2016 Too big to email too. I deleted some detail to get it a little smaller. reference floor issue.plan Link to comment Share on other sites More sharing options...
justmejerry Posted April 9, 2016 Share Posted April 9, 2016 Hi Jim. If you uncheck "wall layers" in your reference floor display options, it will show you all red. Link to comment Share on other sites More sharing options...
Solution Migaloo Posted April 9, 2016 Author Solution Share Posted April 9, 2016 Thank you. That was very simple. Link to comment Share on other sites More sharing options...
justmejerry Posted April 9, 2016 Share Posted April 9, 2016 You're welcome. Not sure why when it is checked that it doesn't stay with the red colour but it can definitely make for confusion. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted April 9, 2016 Share Posted April 9, 2016 Your problem stems from your wall definitions. You need to check the box I have circled in the attached pic for each of your wall layers or else those lines will remain the same color in ALL layer sets... Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 9, 2016 Share Posted April 9, 2016 Copy a close layer-set and rename it to something you will remember. I just use" reference set" after the name, so I know it's for reference sets only. Link to comment Share on other sites More sharing options...
