English Posted March 30, 2016 Share Posted March 30, 2016 How do I add comments to the door and window schedule as I don't see any way to do that in the door dialog window? Thanks Alan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted March 30, 2016 Share Posted March 30, 2016 Click on the door or window. Down in the edit toolbar is a tool called Components. Enter comments in the comment field for the door or window in that dbx. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 30, 2016 Share Posted March 30, 2016 FWIW, you can also edit the "Supplier", "Description", "Code", "Price" and "Manufacturer" fields in that dialog. You will need to find the line that corresponds to the Door or Window itself. Only that line will have any effect in the schedule. Generally, those will be lines marked D1 and W1. Edits made to the other lines will only effect the "Bill of Materials" or in some cases they may effect other Schedules. For example, if you are working with a Cabinet and edit the line that corresponds to a sink it will show up in the Plumbing Schedule. If you select the line that corresponds to an appliance it will show up in the Appliance Schedule. Link to comment Share on other sites More sharing options...
Sydney23 Posted March 30, 2016 Share Posted March 30, 2016 Does anyone know if there are any user-editable fields within the Windows component / schedule table that don't lose their data if I change the size of the window?I just need a place to enter some notes (e.g. "re-measure on site", "don't order till XYZ date", etc) but I need them locked to that window - not disappearing without warning... Link to comment Share on other sites More sharing options...
mkennedy2000 Posted March 30, 2016 Share Posted March 30, 2016 Sydney, short of converting the schedule to text, I don't think so. Perhaps a keyed note would work better? No reason you couldn't grab another unused schedule and create a keyed notes just for the windows if needed. Se ethe recent thread on keyed notes for a video on how to do this or just use a textbox and callouts. Link to comment Share on other sites More sharing options...
English Posted March 31, 2016 Author Share Posted March 31, 2016 Thanks guys. Alan Link to comment Share on other sites More sharing options...
MarkMc Posted March 31, 2016 Share Posted March 31, 2016 I posted an answer to that in suggestions, create sub categories and add to the components list. Yoda (Joe Carrick) taught me this. Link to comment Share on other sites More sharing options...
English Posted March 31, 2016 Author Share Posted March 31, 2016 I just noticed that the door and window schedule is showing some doors and windows with the same ID. They are both the same size but I have several other doors in the plan with the same size but with a unique ID number. This doesn't sound right to me -- shouldn't all doors and windows have a unique ID number?Thanks Alan Link to comment Share on other sites More sharing options...
Sydney23 Posted March 31, 2016 Share Posted March 31, 2016 I absolutely think they should, yes, but I think CA gives them the same ref and then just puts the number of them under quantity. I find that very confusing as if the built opening is slightly out from the plans and you change one window's dims just before purchase, the window then gets its own CA ref number. I would prefer if we could assign numbers and LOCK THEM. Having CA change them without very explicit permission from the user is guaranteed to introduce errors unless you know CA very well and are 100% switched on - I've found it way too easy to make expensive errors. Link to comment Share on other sites More sharing options...
Solution Joe_Carrick Posted March 31, 2016 Solution Share Posted March 31, 2016 I just noticed that the door and window schedule is showing some doors and windows with the same ID. They are both the same size but I have several other doors in the plan with the same size but with a unique ID number. This doesn't sound right to me -- shouldn't all doors and windows have a unique ID number? Thanks Alan In the Schedule, uncheck the box that says "Group Similar Objects". That will give every object a different ID. Link to comment Share on other sites More sharing options...
mkennedy2000 Posted March 31, 2016 Share Posted March 31, 2016 I think CA schedules have some shortcomings - labeling being one of them. I suppose some of the same suggestions made for keynotes could apply to cabinets, doors and windows. It would be nice to edit the item from the schedule and it would be nice to have a less ephemeral way to add comments. Link to comment Share on other sites More sharing options...
English Posted March 31, 2016 Author Share Posted March 31, 2016 Thanks Joe Alan Link to comment Share on other sites More sharing options...
Loekijordaan Posted May 24, 2016 Share Posted May 24, 2016 It is either very late at night, or I am blind as a bat : \ Where do I find the Component Edit button..please help! I am using X8, and feel a bit lost : ( 1 Link to comment Share on other sites More sharing options...
Loekijordaan Posted May 24, 2016 Share Posted May 24, 2016 Ah...found it, but now I need to know if there is a setting to get rid of the dollar sign, as I am in SA, and needs to use the Rand. Thx Link to comment Share on other sites More sharing options...
Andrew Posted June 7, 2018 Share Posted June 7, 2018 I'm still blind as a bat as I've looked at the door DBX and do not see the component edit option. Link to comment Share on other sites More sharing options...
Dermot Posted June 8, 2018 Share Posted June 8, 2018 This is an old thread, in X9 and X10, you don't add comments through the components. You add them through the Object Information panel. 2 Link to comment Share on other sites More sharing options...
