Designer100 Posted March 10, 2016 Share Posted March 10, 2016 (edited) What do I need to do to have interior elevations to be more clearer When plotted to pdf the cabinets to not show up clear Chief x8 windows 10 36x24 layout N.D..layoutFetching info... A.1 Floor Plans.pdfFetching info... Edited March 10, 2016 by Designer100 Link to comment Share on other sites More sharing options...
rlackore Posted March 10, 2016 Share Posted March 10, 2016 Attaching a Layout without the Plan doesn't do us any good. Link to comment Share on other sites More sharing options...
DavidJPotter Posted March 10, 2016 Share Posted March 10, 2016 A layout file is useless without the associated plan files, all you end up with without the plan files is blank layout pages. From looking at the PDF you posted my main observation is that the cabinet elevations would be easier to read at 1/2" scale using a vector camera instead of what you did apparently use. On a D sized sheet for such a small project, upsizing everything is indicated. Clarity is or should be the intended target. DJP Link to comment Share on other sites More sharing options...
Designer100 Posted March 10, 2016 Author Share Posted March 10, 2016 Thank you Link to comment Share on other sites More sharing options...
Gawdzira Posted March 10, 2016 Share Posted March 10, 2016 What type of view are you sending? It appears to be vector with color? Maybe try only vector view with not color for the cabinet elevations. Link to comment Share on other sites More sharing options...
joey_martin Posted March 11, 2016 Share Posted March 11, 2016 1/2" scale...vector view...watch your line weights and text size for consistency. Link to comment Share on other sites More sharing options...
