Dennis_Gavin Posted February 25, 2016 Share Posted February 25, 2016 This is really a pain. I can fix it except for corner cabinets. The info seems to be there but grayed out. Please fix this. Link to comment Share on other sites More sharing options...
dshall Posted February 25, 2016 Share Posted February 25, 2016 This is really a pain. I can fix it except for corner cabinets. The info seems to be there but grayed out. Please fix this. WOW, good catch Gavin Dennis. Yes, CA, please look into this. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 25, 2016 Share Posted February 25, 2016 WOW, good catch Gavin Dennis. Yes, CA, please look into this. ...and make sure to submit it to tech support. I'm pretty sure the reason a lot of issues never get addressed is because we all assume somebody else is going to report it or that posting here in the forum is somehow gonna fix it (which of course it probably won't). Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 25, 2016 Author Share Posted February 25, 2016 OK, I reported it. It was reported before, I believe, except for the corner cabinet part. Link to comment Share on other sites More sharing options...
MarkMc Posted February 25, 2016 Share Posted February 25, 2016 I set the default shelf depth for all my templates back,(and all in user library) which helps make less work to fix. Haven't run into the corner cabinet thing, will check into it. When at machine. Did you try changing to custom front? Think in x8 the shelves are grayed out if it remains default front? Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 26, 2016 Author Share Posted February 26, 2016 Mark - you can change everything but the depth. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 26, 2016 Share Posted February 26, 2016 Under shelves specify you can set the depth. Have done this for regular cabinets, not sure if it works on corner cabinets. Graham Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 26, 2016 Share Posted February 26, 2016 Just checked this out, there is no option to adjust the shelf depth for a corner cabinet. I think for this the only solution might be to set the number of shelves to zero "0" or find another door style that blocks the shelves from flashing through. Graham Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 26, 2016 Author Share Posted February 26, 2016 Please read OP. IT is the corner cabinets that are the problem. Link to comment Share on other sites More sharing options...
MarkMc Posted February 26, 2016 Share Posted February 26, 2016 I'm with you Dennis- back at machine. I see that shelves can't be set on corners. Setting them before changing to corner cabinet has no effect on the shelf depth of the final corner cabinet. Tested several flat panels (framed doors from drop down, custom doors with 1/8, 1/4. 3/8 thick panels) all the same result- I have not been able to get shelves to show through corner cabinet door in overlay. (guessing here but you are using overlay correct?) Not sure what the difference is with what you have and what I did so I got nuttin for ya, sorry. (post the plan?) I stand corrected- just managed to get them to show using perspective floor overview. From pretty high so not something I often do. Would be nice for those of you who do need that kind of view that shelves could simply be turned off in the ALDO. I doubt most building folks are going to muck with changing shelf defaults. I CAN get them to show through (in really extreme POV) using inset cabinets. I'd guess there are camera placements that may be worse than others. The shelf thing has been reported in the past- response was something about Z fighting and the gist was nothing was likely to happen. That being the case I changed my defaults. Guess the reason I haven't run into this lately is all of my base corners don't have shelves since I always place a susan, and I rarely use diagonal wall corner cabinets. More of a problem for me (and why I'm guessing you are using overlay since you don't mention it) is how a pie cut corner cabinet shows if using Inset. Chief adds two extra stiles to the center-nothing like reality-top is Chiefs, bottom is work around. Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted February 26, 2016 Share Posted February 26, 2016 Mark - your bottom config is usually how I do it, just turn the knob off of the apprpriate door. This represents how the doors would normally be in that type of corner unit when hinged together. Graham Link to comment Share on other sites More sharing options...
MarkMc Posted February 26, 2016 Share Posted February 26, 2016 Yeah, it's a work around- top is what Chief does with a standard corner cabinet that is inset- it is WRONG. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 26, 2016 Author Share Posted February 26, 2016 THe cabinet is a susan. THe real problem comes in vector view. In std render view the problem is z fighting. I sometimes like vector view for quick and easy view with clean lines. THe std render view can often look a little hazy. No cabinet door panel definition or should I say little. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted February 26, 2016 Author Share Posted February 26, 2016 "Thank you for your feedback on this issue. I have replicated what you discuss and will be forwarding this onto our Development team to see about getting this taken care of.Regards,KrisChief Architect Technical Support Link to comment Share on other sites More sharing options...
Alaskan_Son Posted February 26, 2016 Share Posted February 26, 2016 I believe you guys, but for what its worth I wasn't able to recreate the problem on my system. Even tried pulling the plan WAY far from 0,0 and still couldn't get shelves to show through. Link to comment Share on other sites More sharing options...
dshall Posted February 26, 2016 Share Posted February 26, 2016 I believe you guys, but for what its worth I wasn't able to recreate the problem on my system. Even tried pulling the plan WAY far from 0,0 and still couldn't get shelves to show through. Admittedly it comes and goes, but I do see it. Link to comment Share on other sites More sharing options...
