ShelbyHall Posted January 20, 2016 Share Posted January 20, 2016 I am looking for some help to bring more natural light into my rendering. I have tried adjusting the default sun and adjusting my lights but my rendering is always dark. My ray trace looks like it is dark out but I want it to look like its daytime. My first image is before the ray tracing and second image is the ray traced image. Thanks! Justin.plan Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 20, 2016 Share Posted January 20, 2016 Opened up your plan and messed with it a bit. Looks like you need to actually add a North Pointer and Sun Angle to your plan. Brightens up nicely... Note: I deleted my previous post because after opening your plan I realized it didn't really apply. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 20, 2016 Share Posted January 20, 2016 Shelby - For sun light you need to put the sun angle and north pointer into your plan. Set the time of day to either early-mid morning or late afternoon to get the sun to come in through the windows. Rotate the north pointer to easily rotate the sun angle indicator. Also, I deleted all but one point light behind the camera. THe one I left was not on so I turned it on. Don't know about the others. I also adjusted the pendants(lower) and recessed lights lower. drop off and cut off angle. There was a texture for the cabinets I think that is not attached. THe slab cabinet doors definitely need work to look good in a ray trace. I did 4 passes. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 20, 2016 Share Posted January 20, 2016 Just to give you an idea of what the sun alone will do, here's a very quick example. Turned off all light sources except for the sun and didn't mess with any materials or settings other than the sun position and lighting intensity. 7 passes...3 minutes. Edit: Accidentally left the ray trace running. Here's 36 passes and 15 minutes. Link to comment Share on other sites More sharing options...
ShelbyHall Posted January 20, 2016 Author Share Posted January 20, 2016 Thank you for all your help! I Turned off all of the lights and adjusted the sun to shine through the window and it is still really dark. This was 14 passes Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 20, 2016 Share Posted January 20, 2016 Thank you for all your help! I Turned off all of the lights and adjusted the sun to shine through the window and it is still really dark. This was 14 passes I'm sorry, I didn't mean to suggest that you turn all the lights off. I was merely trying to show what could be accomplished without them. Try adding some light sources back in, maybe mess with the intensity settings in the Ray Trace DBX... And try turning up your ambient lighting settings under 3D View Defaults... Here's a quick example done without any lights (not even a sun). Ambient lighting settings down near 20% (don't remember exactly what I set them to)... Here's another one. Again, without any lights. Ambient lighting settings at 100%... I'm not exactly a ray tracing expert, but hopefully messing with those settings in combination with the north pointer and sun angle (as previously mentioned) will get you closer to what you're looking for. Link to comment Share on other sites More sharing options...
ShelbyHall Posted January 20, 2016 Author Share Posted January 20, 2016 Thank you so much for all your help! I think I got finally got it to a good place. Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 20, 2016 Share Posted January 20, 2016 Thank you so much for all your help! I think I got finally got it to a good place. You're welcome. Looking good...and much brighter : ) Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted January 21, 2016 Share Posted January 21, 2016 Shelby - good ray tracing takes some time and patience. It's not a flip the switch kind of thing but more of an art form. You have to experiment with different types of lights and their locations until you get what you want. ALso, the adjust image properties as Michael suggested. Different scenes with different elements and textures present their own challenges. Good Luck! Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 21, 2016 Share Posted January 21, 2016 Well said Dennis. There are settings, lights and, material types & properties that all impact on a scences final look. Add to this the users intent and the time one is willing to spend, there are many variables one needs to get thier head rapped around in order to generate a predictable and consistent scene. As you indicate, there is no simple single type of switch one can flip to make it all come together. Given this reality I can only suggest that one must take the time to systematically experiment with a scene in an attempt to understand how it is impacted by a particular setting adjustment. In the meantime, as Shelby did, post your issue and there are many great people here that are more than willing to share their experiences and knowledge to assist. This original posting is a great example, within about 4 hours the improvement in the Raytrace result is Night & Day. Graham Link to comment Share on other sites More sharing options...
warrenwest Posted January 21, 2016 Share Posted January 21, 2016 and on that topic I am busy with a small kitchen for a client and just when you think you are getting the hang of it the ray trace Gods decide otherwise. Below you can see that even with ambient lighting turned up and natural sunlight flooding in, it still seems 'dark' to me. I would also like to see more definition between the doors and drawers ( gaps) to make it more realistic. It still seems so artificial. I ran this for 18 passes only. Any other advice? Link to comment Share on other sites More sharing options...
Alaskan_Son Posted January 21, 2016 Share Posted January 21, 2016 and on that topic I am busy with a small kitchen for a client and just when you think you are getting the hang of it the ray trace Gods decide otherwise. Below you can see that even with ambient lighting turned up and natural sunlight flooding in, it still seems 'dark' to me. I would also like to see more definition between the doors and drawers ( gaps) to make it more realistic. It still seems so artificial. I ran this for 18 passes only. Any other advice? Three things… 1. Make sure you turn on ambient occlusion (for the door details to pop a little more). 2. Consider adding some interior light sources to brighten it up further (shadows off). 3. Once the ray trace is completed try adjusting the image properties. Link to comment Share on other sites More sharing options...
warrenwest Posted January 21, 2016 Share Posted January 21, 2016 Aye aye Capitan. Will get right on it. Thanks ! Link to comment Share on other sites More sharing options...
warrenwest Posted January 23, 2016 Share Posted January 23, 2016 Applied the advice Michael and the result is below. I did change the upper cabinet color to a darker shade of grey and the render did come out better overall. However I still have the white 'glow' where there should be a dark shadow in the gaps of the cabinets in the sink area. 221 passes. Can anyone help me get rid of this pesky issue? ( without recommending additional software like lumion ) Any ideas are welcome Link to comment Share on other sites More sharing options...
TheKitchenAbode Posted January 24, 2016 Share Posted January 24, 2016 You should post the plan. It's not possible to provide specific guidance without it, just too many variables. Graham Link to comment Share on other sites More sharing options...
DRAWZILLA Posted January 24, 2016 Share Posted January 24, 2016 I would add some light sources in the kitchen to even out the shade vs light areas. Link to comment Share on other sites More sharing options...
ThomasM Posted March 13, 2016 Share Posted March 13, 2016 Shelby - good ray tracing takes some time and patience. It's not a flip the switch kind of thing but more of an art form. You have to experiment with different types of lights and their locations until you get what you want. ALso, the adjust image properties as Michael suggested. Different scenes with different elements and textures present their own challenges. Good Luck! I knew this but forgot. I have been just letting ray trace do its thing. today I started with the sun angle but getting a lot of sparkles when I ray trace. thanks for the reminder. Link to comment Share on other sites More sharing options...
