AlexAncon Posted January 2, 2016 Share Posted January 2, 2016 Is there a way to "un-hatch" a wall after using the build>wall>hatchwall tool other than undo? Seems like there used to be a very easy way to do it but I can't remember. 2016? Time marches on. Thanks! Link to comment Share on other sites More sharing options...
DavidJPotter Posted January 2, 2016 Share Posted January 2, 2016 You can turn off that named layer in Display Options or redraw over the wall. DJP Link to comment Share on other sites More sharing options...
Solution DRAWZILLA Posted January 2, 2016 Solution Share Posted January 2, 2016 Select the wall, hit the tab key, delete. Just look a the bottom to verify you have the hatch before deleting. 1 Link to comment Share on other sites More sharing options...
AlexAncon Posted January 2, 2016 Author Share Posted January 2, 2016 Thanks Perry! That was exactly what I needed. It is a LONG wall with a lot of doors etc and I really hated to rebuild. Link to comment Share on other sites More sharing options...
RodCole Posted January 2, 2016 Share Posted January 2, 2016 Another thing that can be handy when working with Hatches is to have the Hatch tool active and group select all of the walls you wish to either change the hatch fill style on or delete all in one process. It should not be necessary to tab to the Hatch when using this method. Thank tech support for this tip. It can be handy to place the Hatch tool icon on your toolbar if you think you might need it fairly often. I put mine at the end of the line of Wall tools. This way you can see that the Hatch tool is active, and just to be safe, check the status bar at the bottom of the screen as Perry mentioned. Link to comment Share on other sites More sharing options...
glennw Posted January 2, 2016 Share Posted January 2, 2016 I am curious why you would use the hatch tool to hatch a wall as opposed to defining the wall with the appropriate hatch patterns? Link to comment Share on other sites More sharing options...
RodCole Posted January 2, 2016 Share Posted January 2, 2016 So that objects placed inside walls "Framing Hardware" can be seen in Wall Framing Plan View. This requires that the fill style be none or the symbols are obscured by the fill. I don't like the way the Hatch tool works, but it is the only option that I know of that allows for various types of fill styles placed on separate layers for display purposes and that allows for symbols to show inside the wall's main layer. Link to comment Share on other sites More sharing options...
tommy1 Posted January 3, 2016 Share Posted January 3, 2016 Once the wall is hatched another way to remove the hatch is click on the hatch tool again. Now when you select the hatched wall, it will select the hatch first instead of the wall. Link to comment Share on other sites More sharing options...
glennw Posted January 3, 2016 Share Posted January 3, 2016 Quote So that objects placed inside walls "Framing Hardware" can be seen in Wall Framing Plan View. This requires that the fill style be none or the symbols are obscured by the fill. Rod, Did you know that you can specify a hatch pattern assigned to a wall layer to be transparent? Link to comment Share on other sites More sharing options...
RodCole Posted January 3, 2016 Share Posted January 3, 2016 Yes, that is the point. It has to be none, or transparent for the symbol to show if it is placed into the wall. What I would really like is to be able to have an option on the Hatch tool that would place the hatch only on the main layer of the wall. The problem is that what ever the fill style is that is assigned in the Wall Definition, that is what shows in all Layout views unless a hatch pattern is assigned to a visible layer. It would be nice to be able to have a bit more control over the Wall Definition's fill style per view. Another way to deal with this situation would be for Walls and Symbols to have control of display order. Link to comment Share on other sites More sharing options...
