Keith_A Posted December 27, 2015 Share Posted December 27, 2015 I have a plan that was sent from the Architect in a DWG plan file that I need to duplicate and build out. I am having the most troubling time with walls and automatic connections, intersections, and the like. I have tried to do the simple version of no wall layer and just a main layer, tried layers with appropriate dimenions, and I am at a loss. What methods would you use to create walls like this Link to comment Share on other sites More sharing options...
MPDesign Posted December 27, 2015 Share Posted December 27, 2015 looks like brick walls, 4 or 6" or a custom thickness. measure the dwg wall thickness and figure out an appropriate wall type. or make a new one to work Link to comment Share on other sites More sharing options...
Steve-C Posted December 27, 2015 Share Posted December 27, 2015 I agree with Michael, just create a new wall that looks like that one. Of course, surface layer specs may come into play at some point. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted December 27, 2015 Share Posted December 27, 2015 Is there a wall legend in the plan? If not contact the architect and ask for details or just a verbal on what comprises the walls. Link to comment Share on other sites More sharing options...
Keith_A Posted December 28, 2015 Author Share Posted December 28, 2015 These are all existing Masonry type walls in an existing structure. The thickness varies from 12", 14" 18" to 30". The problem I am having is the wall intersections and getting them to "shape" and follow the lines of the existing structure. I can build the correct thickness wall, but controlling how and where the walls connect is the issue that is the greatest difficulty. I have tried every combination of wall intersection edit handles that I can think of and none of them will produce the proper connections. One the angle bay style wall I have tried every type of varying thickness wall to redevelop that layout. Surface layers aren't an issue as the plans i am responsible for don't require layer details, just placement of fixtures, cabinets, electrical, etc.. The wall legends for the existing walls just show Adjust CMU Walls as per plan. Link to comment Share on other sites More sharing options...
Keith_A Posted December 28, 2015 Author Share Posted December 28, 2015 Alright - I think I may have figured out a solution, maybe not a proper solution but this is my idea. All the files I received are CAD files in DWG, so when I import them I get CAD lines and boxes. Instead of trying to rebuild the walls in the entirety I have traced all the interior walls with a room divider (that way outlets and objects will snap to them). Then I just filled the CAD lines with Solid Polylines with the proper Fill Style. I am pretty sure this is not the best or correct way but I think it will work for what I need. Anyone have a different idea that may be better? Thanks to everyone who replied. Link to comment Share on other sites More sharing options...
keithhe Posted December 28, 2015 Share Posted December 28, 2015 Just a guess, but having imported some CAD drawings, I agree with what others have said. The CAD file you have is showing a combination of probably brick (where you see the wider areas) and perhaps siding where walls are a "normal width". These are not a single wall type, different types for how the outer accent (surface layer) is. The DWG is simply showing the bounds (outer and inner) of the walls, and you will need to know what those layers are. This can be done, but you really need to know what those "lines" in the DWG represent. Post the CAD file (zipped as CA won't allow it attached otherwise), and the "plan" you are working on. I'm betting we (maybe not me, but one of the smart folks on here) can get it represented correctly. Link to comment Share on other sites More sharing options...
keithhe Posted December 28, 2015 Share Posted December 28, 2015 Here, by way of example, see attached. In my case I have a brick wall intersecting a siding layer. Note that CA will show all layers, or just outer if you choose. CAD files are just lines representing the outer and inner most part of a wall. See plan attached, and two JPGS CAD Walls.plan Link to comment Share on other sites More sharing options...
Keith_A Posted December 28, 2015 Author Share Posted December 28, 2015 I wish I could, I can't distribute the entire CAD File I was only able to get permission for the screen shots of limited views. Link to comment Share on other sites More sharing options...
keithhe Posted December 28, 2015 Share Posted December 28, 2015 OK, that will make it a little harder for you, but my example above is what you have, you just need to define your wall types to reflect the CAD files you have. Good luck.... Link to comment Share on other sites More sharing options...
glennw Posted December 28, 2015 Share Posted December 28, 2015 Keith_A, Can you post the Chief plan file, or at least part of it? Don't worry about the .dwg file if it is a problem. Have you tried the Edit Wall Layer Intersections tool? I think your problems are caused by you using single layer walls which don't allow for many intersection alternatives. Link to comment Share on other sites More sharing options...
