Drawing a Simple Cinder Block Wall
Rich_Winsor
You know, it's funny how sometimes the most seemingly
simple task can turn out to be an ordeal. I needed to model
a short section of cinder block wall that is holding up a roof
support beam in a carport (see first thumbnail) . Easy peasy,
right? 21 blocks (14" long x 7 1/2" wide x 6" high) stacked
in 3 columns. Well, after 45 minutes of futzing around with
those confounded pattern and texture settings in the "Define
Material" dbx I was still unable to get a wall that displayed
properly with all the rendering techniques. Finally I just gave
up and in about 15 minutes modeled the wall section out of
Polyline Solids and converted it to a symbol. Not only does
it display properly in all views but I can change the color of
the grout if I choose to do so.
Am I missing something? Is it possible to create this simple
wall section using Chief's Wall tools?
You can get pretty close with a standard Chief texture, but you need to adjust the X-offset of the pattern and texture (depending on where the wall is in the world space), and you have to live with the fact that Chief doesn't apply textures to the top of walls properly:
post-95-0-01679900-1444653008_thumb.pngpost-95-0-39786400-1444653028_thumb.pngpost-95-0-65519900-1444653047_thumb.pngpost-95-0-78483900-1444653057_thumb.pngpost-95-0-31439500-1444653070_thumb.png
Thanks for having a look Robert. You tweaked your
texture settings more finely than I did but it looks like
we have similar results. Pray tell, how did you calculate
the amount of the texture X offset required? Or do you
just do like I do and plug in some values and watch
which way the Texture moves? I find the Pattern offsets
are fairly straightforward and I usually get the anticipated
results, but the Texture offsets and Scale settings are a
mystery to me. I have no idea what they are in relation
to. Is there some way to calculate the what the values
should be other than by trial and error?
Just like you - trial and error. I know we've had a few forum posts discussing UV mapping in Chief; this conundrum is another example of how we need better controls.
Or better visual feedback while you are still in the dbx as to what the change is going to look like without having to close all the dbx's only to find that was not what you wanted. The little teapot is a start but will not tell what it is "really" going to look like on a wall, solid, material region, etc.
Mike
Mike
Amen Mike. As I mentioned, the little Pattern graphic
sort of works that way but the Texture visuals in the
dbx remain unsolvable to me. That teapot is a crock ;)
and the cube isn't much better. Anyhow, in this case
my wall symbol functions just as I want it to so I will
stick with that approach for now.
Here is my wall symbol at work. Still haven't fleshed
out the landscape but the structures are looking good.
Just an update for anyone who may be following along
at home. Here is the completed carport with the funky
cinder block wall segments.
BTW, (standing up and shaking my fist at the monitor and
          probably about to regret making this statement ;) )
I defy anybody to create that right side carport wall using
Chief's wall tools and textures so that it will display properly
in all view types. Here is a "crappy" 10 pass ray trace and
the corresponding watercolor w/line drawing showing the
results.
What is that kind of 'pop out' upper wall ?  Storage ?  Shelves inside ?
Never seen that before.
And if your lucky Jere, you won't ever see that construction.
I'm not sure what is keeping the whole thing from flopping
over. Believe it or not that pop out upper wall is basically
cosmetic. I'm not sure what look they were going for. Sort
of a poor mans "Falling Water". Unfortunately a more
appropriate description would be "Falling Market Value".
The cinder block sections have a rudimentary anchor for
the vertical 4 x 12 posts. The vertical 4 x 12's have no
hardware securing them to the horizontal 4 x 12's above
them. In fact 2 of the horizontal roof support beams are
not even seated on the corresponding vertical posts.
I think the way you ended up building those walls (solids/symbol) was the best way.  Just for the heck of it I tried to use the wall tools to reach the same result.  Here's the best I could do.  Its not bad, but what you did was better.
That's a lot better than what I had with the wall tools Michael.
If I had gotten that close I probably would have run with it. I
haven't had a chance to look at your plan yet to see how you
got the top of the wall to display properly. Anyway I'm happy
with the wall symbol because it just looks more like a cinder
block with nice crisp edges and there is the added bonus of
being able to change the color of the mortar.
Rich,
You said earlier that you could change just the grout color. Can you explain how you would do that?
Also, any chance we can get you to post that symbol? (Would understand if you did not want to.)
Thanks
Hey Mickey,
When I constructed my wall section I used different Polyline Solids
for the cinder blocks and the mortar in between them. Then when
you convert the model to a symbol you can assign different textures
and colors to the individual parts. Now when you open the object
you can change these features using the Materials tab.
Cinder Block Wall.calibz
Thanks for taking the time to show that.
Craziest wall structure ever.
Plan checkers nightmare.
