newel post orientation
Dennis_Gavin
Dennis................Do you want the angled newels set at 22.5 degrees so the railing on both sides of the newel come into the newel at the same angle? If this is the case then you will probably have to go with Ray's suggestion. I run into this problem many times and up to now aways have gone with Ray's solution. If there is a better way I'm all ears.
Joey - as Larry suggests I want the rail to come in on one side of the newel.  Not on the "point".
I have been running the last couple of days and just dropping back into the forum to check up
on things.  Thanks all for suggestions.  I still consider this a problem area for chief's railings.
