Metric Conventions
Joe_Carrick
For you metric users, I have a question about how areas are generally indicated on your projects for various components.
1.  Site, Rooms, etc in Sq.Meters(sq.m.)?
2.  Doors, Windows, Counter tops in Sq.Centimeters (sq.cm.)?
3.  Other items ?
4.  Is anything (such as cross sectional area of framing members, etc) in sq.mm. ?
IOW, what are the standards?  For Imperial projects we use a combination of Sq.Ft. and Sq.In.
My guess is that metric would generally use Sq.M. ad Sq.Cm. but I really don't want to guess.
Joe,
We usually use m² for site and floor areas.
Same for counter tops, windows, doors, etc - this format can cover a huge range of areas.
We may see sq m sometimes, but I try to avoid that.
If a property is very large, we will use hectares. (1 hectare = 10,000 m²).
It is not usual to call up cross section areas for framing members, but if the area were very small, we would use mm² - I don't think I have ever used this.
We never use square or lineal centimeters.
Thanks Glenn,
I have bee working on some Macro Packages for Area Analysis [building, Site, Openings (Doors & Windows), Vents] and also a basic structural member sizing package] which I want to make sure works for both Imperial and Metric.  Based on your input, I will make most things in sq.m.
Thanks
Some more questions:
In the USA & Canada most building products are Imperial units (ie: 48"x 96" Sheet Goods, 2x4 (1.5" x 3.5") Lumber, etc.
These are not round numbers in metric so I would assume that outside of North America those materials come in different sizes.
What are the common sizes in Australia, Europe, etc?
Joe
Gib (sheetrock) 1200mm or 1350mm wide x various lenghts ie 2400,3000,3600,4200,6000.
Other products -ply 1200x 2400mm or 2750mm
                         - MDF flooring  1800mmx3600mm
                         - Hardies sheets 1200X2400mm or 2700mm
                          framing timber typically 45 wide x 90,140,190,240,290mm deep
