Larry_Sweeney Posted July 14, 2015 Share Posted July 14, 2015 MY CHALLANGE OF THE DAY I'm working on a restoration project for a 1830 Pa. stone house. The casings (all trim) is attached directly to the studding and the plaster comes up to the casing. I show in the following attachment what I'm after and what I've been able to accomplish so far. I realize I can't get the rabbeted jam (or can I?), but (1) is there any way to flush the face of the door to the trim? (2) I would also like to get the casing on the inside of the door to be next to the studding. I thought by changing the "jamb settings" could possibility do the trick, but I'm getting nowhere. I was able to get the trim against the stud on the front side by changing this setting. . Does anyone have any work around suggestions to get these items accomplished? I suppose not to many of you come across this type of construction, but doing a lot of restoration work I run into it all the time. I know I can just make a cad detail of this, but it would be nice to somehow figure CA out to accomplish it in the model. Thanks for any and all advice. It's always appreicated. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted July 14, 2015 Author Share Posted July 14, 2015 I just realized I put this thread in the wrong discussion area. I wanted it in the Q&A. Can someone tell me how to move it? Thanks Link to comment Share on other sites More sharing options...
Bill_Emery Posted July 15, 2015 Share Posted July 15, 2015 I'm going from distant memory, but I think you can get much of what you want with a custom door symbol. likely it will look good in 3D, elevation, and section; but may not be right in plan. I've gotten away from using custom window and door symbols as they are essentially broken in recent versions. I may give it a try in the morning if things don't get too busy. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted July 15, 2015 Author Share Posted July 15, 2015 Bill...............Whenever I'm trying to to figure something "out of the box" with this program I almost always expect to hear from you.--------If I don't then nine times out of ten I figure it can't be done. I'll be looking forward to your suggestions. Have a great day. Link to comment Share on other sites More sharing options...
Gawdzira Posted July 15, 2015 Share Posted July 15, 2015 I am not sure if this is too much work but see the attached plan for one idea. Check the settings on the interior wall.The drywall surface is a material region. jamber.zip 1 Link to comment Share on other sites More sharing options...
Bill_Emery Posted July 15, 2015 Share Posted July 15, 2015 I like Allen's idea. That's a lot easier than making door symbol that would be, and a lot less limiting. Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted July 15, 2015 Author Share Posted July 15, 2015 Alan..........Nice--I like it. It could be a little time consuming if I were showing that detail for an entire project, but It gets my casing where I want it. I'm going to "play" with your idea a little more and see if I can somehow improve on the "time" factor. Thanks and have a great day. Bill...........The reason you were using a "custom door symbol" was so you could get the face of the door and casing on the same plane as I show in the first thread? Link to comment Share on other sites More sharing options...
ShaneK Posted July 15, 2015 Share Posted July 15, 2015 Make casing only 1/16" in depth Link to comment Share on other sites More sharing options...
Larry_Sweeney Posted July 15, 2015 Author Share Posted July 15, 2015 Shane.........Doing it like you state will get the door near the face of the 1/16" casing surface, but to use the casing I show in my first thread this won't work. At least I don't see how it would. I would have to "install" the casing I would want to see, using a 3D molding p-line and that will put me right back where I started. Then again maybe I've had to much coffee today. Link to comment Share on other sites More sharing options...
ShaneK Posted July 15, 2015 Share Posted July 15, 2015 Looks like "suggestion" time, both work a rounds take TIME. Link to comment Share on other sites More sharing options...
Gawdzira Posted July 15, 2015 Share Posted July 15, 2015 Once you set the default for the wall material you only need to click once on each wall in a 3d view. The other item that would need tweaking is the baseboard or crown. I did not try adjusting the thickness of the base to get it to show. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted July 15, 2015 Share Posted July 15, 2015 Alan, I think if you use the "Make Room Molding PLine" Tool before applying the Material Region then the Moldings will be correct. 1 Link to comment Share on other sites More sharing options...
