RevitCADmaster Posted June 8, 2015 Share Posted June 8, 2015 I am new to CA I am trying to bring in either a DXF or PDF file into CA and then trace over it. The first time, on my machine I got thr PDF in but did not know how to place it behind the resulting geometry. I got that solved, but now I am on another machine and when I bring the PDF (or DXF) into the project I get nothing! I don't know if the file is behind the empty screen, but I need to be able to see it to trace over it. This is an empty file with the standard template. All right out of the box. What am I missing? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted June 8, 2015 Share Posted June 8, 2015 It could be a lot of things. Maybe the line color imported is white, or it could be something else. There's no way for us to tell what the problem is without having the file. Link to comment Share on other sites More sharing options...
Kiwideziner Posted June 8, 2015 Share Posted June 8, 2015 Another guess try turning on all layers to see what layer it is on. Link to comment Share on other sites More sharing options...
Kbird1 Posted June 8, 2015 Share Posted June 8, 2015 I think they are imported on the CAD, Default Layer , so check if that Layer is Displayed by default ( (Active)Display Layer Options) in whatever Set you are Using. Link to comment Share on other sites More sharing options...
thorn-ecoc Posted June 12, 2015 Share Posted June 12, 2015 Not sure why you don't see your import, but I have a suggestion. When importing, I find it's best to place it on a layer I don't use, like "fences", instead of letting it go the the default cad layer. Often you will want to not show the import, but still want the cad items shown. Link to comment Share on other sites More sharing options...
kMoquin Posted June 12, 2015 Share Posted June 12, 2015 If you are on another machine the path to the PDF is likely different. You need to reestablist the path in Chief through the pdf's dialog box. Link to comment Share on other sites More sharing options...
