AI [Claude-Pro] Auto Generate As-built
jtcapa1
Thanks to CA, Claude and Rene, I stumbled my way through linking Claude to the MCP in CA.  After a few back and forths I was able to run a fresh version of X18 and sent a prompt to Claude to create the entire As-Built plan using Rene's Pro-Plan, which I still don't understand but fortunately Claude does!  It worked for 25 minutes with nothing more than a real estate PDF floor plan, slightly blurry, and it managed to create a 20 sheet set that is about 80% fleshed out.  This is after I spent 24 hours doing the exact same thing by hand.  Claude caught so many things I missed, plus because MCP is "experimental" I did get a few of these error messages:
"The skill and memory are saved. Chief closed unexpectedly while I was working, so I’ll relaunch it to finish the title block and the delete layer move.
Chief is back up. Next I’ll check for any recovery prompts."  Normally, when I get these error messages I push back from my computer and yell at the sky in 'Wrath of Kahn' fashion... " I spit my last breath at thee",  No sooner did I utter those words Claude calmly worked around the problem with a warning that I should now save the program before it went on.
This is the future of our drawing creating process, thanks to brilliant people like Rene, we now have some very powerful tools that integrate so well into CA, that I now have confirmation that Rene is not really a human, but an advanced AI human looking robot.  Puts back some of the fun in drawing creation.  Rene has a quick condensed video of his first attempt at generating a new ADU plan.  Pretty freaking amazing stuff.
interesting, so out of the 24 hours, where did it do things 40 times quicker. i.e. did it do some things better than others?
Did it include elevations? sections with proper heel height, height above grade? realtor floor plans here are just floor plans. The trickier part (and vast majority of my time) here is getting the elevations correct from photos
Edited by SHCanada2
Haha, believe it or not I always  send these types of posts to my mom...and she would probably agree with you had she not been there :)
  • Like 2
What kind of stuff is included with the 80%?  Is it because of Rene's Pro Plan or is it from the web based monster LLM?
Does it include all of the meat and potatoes like proper wall components? Interior bearing or 2x6 utility walls specifically placed? All of the different window and door defaults correct (size, type, configuration,..)? Proper Floor components, different where required (Basement, Main, and 2nd Storey may all be different)? Roof over hang(s), layers of components, heel heights, materials, different pitches... all proper? Framing components proper, truss vs joist, 16" vs 24" o.c., any beams and posts placed? Are the floor joist in the proper direction(s)? Do interior doors have proper headers vs non-bearing door headers? Any decks or outside rooms to proper size, heights, components, materials, railing, stairs, and framing correct?
I am just curious how the web based models are handling the many changes that we make throughout the plan on the fly. I haven't used any web based LLM's yet, but I am working on a locally run program to inject all these 'changes' we instinctively do. Plugging in a picture and then going back to rewrite walls to be bearing (with the door to have a 2x10 header), then changing the floor system to handle the span seems like more work than just drawing the wall and changing the floor structure manually.
I'm trying to fill the need for my location. I currently have an as-built that has had three distinct structures built over the span of about 150 years, as you can imagine it all started with hand hewn lumber and a rock foundation and ended with dimensional lumber on poured concrete. I'm not sure that the web based models would be much help with my site gathered data. It's coming together slowly as I learn 'computer language', but it is a lot of work and hopefully will build a strong base to eventually get practically the whole house correct without costing any token expense.
I suspect that LLM's are still struggling a bit building kitchens and CA hasn't released the placement of library objects yet (there may be a couple of work arounds currently in the mix) so I'm just trying to get a feeling if the effort I'm putting into getting my locally run project off the ground vs just paying for tokens and have the big guys do the heavy lifting is worth it.
I have a few things going for me with the Pro Plan that make a pretty substantial difference here, and a huge part of that is the infrastructure behind it.
I’ve been developing these templates for ten years, with a major increase in development hours starting with X16. Between X17 and X18 alone, I put eleven months of dedicated, full-time development into the system. There’s a tremendous difference in how much you can build when you’re working on it every single day for four, five, or six months straight, compared with making incremental changes as projects come along or occasionally dedicating a day to your template.
And that work extends well beyond the template files. Behind the scenes, I have years of Discord support conversations, years of training specialized bots, years of collecting details, and years of documenting workflows I’ve developed. I’ve taken transcripts from my YouTube videos and built specific workflow instructions from them. Add my manual, my own testing, and all the questions and solutions that come out of supporting people using the system, and it becomes a huge body of information.
That’s a major part of what makes my AI setup function well. I have a large body of specialized data to work from, built through the process of creating, refining, explaining, and supporting these templates over many years. The AI has access to detailed information about how the system works and specific instructions for using it.
Because I’m developing this as a product for a broader community, I also put a lot of time into making those workflows repeatable and scalable. The views, macros, project information, and shortcuts need to work across different projects and for different users. That consistent structure also makes it much easier for AI to interact with the system efficiently.
In JT’s case, I think a substantial part of the improvement came from going from working without my templates to working with them. There are already a large number of established, linked views in the layout, along with scalable macros and systems for managing information. A considerable amount of the setup work is already there for the AI to use.
I also include specific AI skills in the Pro Plan and keep improving them. Those cover things like working with my title block and specification system, looking up and filling in project information, importing topography and parcel maps, and completing layout page information. Those skills give the AI a defined workflow for tasks it would otherwise have to figure out.
For drawing, my own setup also uses MCP to coordinate actions with Python scripts that speed up portions of the process considerably. I’m testing a new method now that, in my testing, makes those drawing operations easily 40 times faster than using MCP out of the box. I’m still working through the details, and that comparison is separate from JT’s overall time savings.
As for exactly what his run accomplished with elevations, sections, heel heights, or grade, I’d need to review his result. But the established views, the scalable structure, and the years of specialized information behind the Pro Plan are a huge part of why the AI can accomplish so much so quickly.
Also, keep in mind all of my specialized tools. If you’ve watched my Template Tuesdays videos, you’ve seen that those tools can be assigned hotkeys. Python scripts can trigger those hotkeys, which gives the AI another way to execute a prepared workflow.
So the process looks like this: you give the AI instructions, it uses MCP to coordinate the work, and when it reaches an action that I’ve built a Python script for, it can run that script. The script then executes the prepared actions, including triggering the hotkeys for my specialized tools, before the AI continues with the next part of the job.
For supported actions, that can be dramatically faster than having the AI work through every individual step with separate MCP calls. A whole sequence of actions can be packaged into a repeatable routine.
There are a lot of nuanced details in making that work reliably: how the tools are configured, which hotkeys are assigned, what state Chief needs to be in, and when the AI should use each script. That’s another place where the years of development behind this system pay off. I’m building shortcuts around established workflows that can also be taught and shared with other users.
when I first tried it(I think I mentioned this in your other post which you showed the tracing) chatgpt suggested a python script to execute against the realtor floor plan in order to generate instructions for the MCP server. It built me one a couple weeks ago, but I havent tried it yet. In my view of the world :)  I would prefer that execution model to at least get it to draw the floor plan  from the realtor plan, as it would be a deterministic repeatable execution, and easily portable. That said, I havent tried it yet to see it is even close.
But maybe back to my question, for a realtor floor plan(which has no elevations, no details), how long is AI taking to trace it (if you are still doing it like your other video, or maybe per your above video it looks like you might be using an execution set from python or something else, and you look to have described as such in the comment above), compared to drawing the walls manually in CA. Because everything else beyond that is your pro plan template and its automation (combined now with AI)
That was kind of my guess, it had to be something more than AI drawing the walls from a realtor plan(which here do not have the windows WXH). I draw walls from realtor plans pretty much on 50% of what I do, and most of the time they are relatively simple and might take 2 hours to do just the walls (sometimes its like 30 min), not 24 hours. Then I go to site, measure and then fix the walls to match reality :) , then I do elevations and roof work.
I've seen you have come so far in the last few weeks, it might make me get off my butt and try that python script AI created for me. My future plan for when I have to go to site anyway is to slam lidar scan it, get the point cloud, use the HW manuf software to get the walls, doors, windows (only a couple vendors do this automatically at the moment  and I have only seen one that has windows WXH, location to wall, sill height. and I doubt they are 100%), or cut the sections/elevations and then have a script to generate the execution for CA. And if it gets good, it will also set the roof parameters and heel height based on the sections, and if I'm really really lucky, it would set the terrain and exterior number of steps with correct dimensions. Thats all I kind of need for most of my work. I think the roofs will be the one which may take the longest to automate, i kind of expect AI will just draw roofs rather than use the roof directives. and then I predict AI to start creating its own work arounds when things dont quite line up. It will start masking, coloring, etc. it will be entertaining to see what it does
In other words, I would like to automate the plans from a raw building scan. There seems to be a few companies trying to do this for revit, but I have yet to see them do roofs, elevations yet. at the moment they are focused on floor plans. Given scanners are now in the sub 5k range for 1 inch accuracy (or so they say), I think that will be the future...unless of course the iphone puts a better lidar sensor in their phone, then that could be a game changer.
and if it can do all that automation while I am out for groceries I will be quite happy.
..but I'm still left wondering how JT got a full set of plans in 25 mins even with your automation from the realtors floor plans, because here, they have no elevations. Your template produces the elevations, but one would have to know the pitch, the heel, grade and grade changes, window sizes, locations, for the elevations to actually be correct.
In other words here, in order to get a correct set of plans, one has to get all of that information from sources other than the realtor floor plan, and that takes the time, even if the instruction was as simple as please look at these pictures and determine the grade difference to the main floor, and create a terrain.
Edited by SHCanada2
I only got a full set of plans because I'm using Rene's Pro Plan templates.  The plans just seemed to auto populate because of how Rene had already integrated so much scripting into his templates.  It created the plans as an "as-built", nothing new was yet designed, but what I'm doing with Rene's help is building these "skill sets".  One project I've committed to using this on is mostly an interior remodel, but for an Engineer that works for Google's AI department, an she gave me the confidence to just start talking with it and telling it what I want as a "skill set" and the Agent starts to learn the entire system of Chief then the Pro-Plan Addon, then my preferred method of setting up plans for each of my jurisdictions.  More importantly, I asked Claude, how best to work with it as I make corrections or additions from its work, and created something for me called a "gap report", where it suggests a plan of attack on what I should address first.  It seems well equipped to deal with jurisdictional changes, as it already flagged many things I had missed.  I also decided to try a mock submission and asked it to double check the data it/we had created against that jurisdictions code and submission requirements and it handed me a check sheet of all the things I need to change, correct and add before they would let me submit!!  Something the building departments are already doing on their end to keep projects from just coming in their doors.
With Rene's help, this is going to be really fun.
On 11/19/2026 at 7:55 AM, SHCanada2 said:
the curiosity is killing me as to how it gets a 50 times improvement (25 min compared to 24 hours), with just a realtor floor plan.
@jtcapa1  any details you can share?
It is a full set, but only of the as-built condition, plus lots of errors.  Right now it is like handing an early project off to my 1st year draftsman to mock up the set for this client, when they don't really know much about the scope or desire for what will happen.  It is a rough template filled out.  What I see though is AI fast learning curve. By the end of this project my 'draftsman' will be a 'lead draftsman' and soon a design partner as well.   Almost all my clients are now using AI to generate their design idea's so it seems a natural fit to us AI to polish things up, and my job is to double check everything after it does the same.
Trust me, this is a real game changer, and I know CA knows this.   I applaud them dropping in that 'experimental' MCP feature.
I have to say, the program did "error" out 3 times when I first ran Claude through fleshing out the project.  Errors I would have been forced to start over from, but AI did not even hesitate, it simple worked around those errors and found a path that worked.  Something I never really could.  Wow.
It used both!  It also managed that MCP portal with ease. It does need more verbal direction on using all the power of Rene's Pro Plan, but that is the beauty of just talking with AI like a 1st year draftsman, you have to be very specific about what  you want, and the more of that kind of information you give it the better the outcome.
interesting, I'm curious about the roofs. do you tell it to use roof directives, and then tell it what to fix? On a regular basis I need to lift certain roofs, edit them around corners, put in ckickets etc to reflect reality. I'm curious how one would talk to it to accomplish this. Or are you going to make my day and tell me you gave it a picture and it edited the roof planes and raised them to make it match the picture?
I think this is what I am missing, it is an interior project, and the AI drew the floor plans from the realtor floor plans. no roofs, no exterior elevations required? Curious about window size, sill height, type and location. Do your realtor plans in your area have those details? Ours do not. Did AI place them somehow automagically? or are you using the LLM to tell it where to place them? If the latter, was it quicker than doing it by hand? i.e. if that information is on some sketch or something, how is that being translated into CA. It would really make my day if you told it the sketch was of the kitchen, and it looked at the chicken scratches for the dimensions to the wall, sill height etc, and then drew that window in CA. but if you were reading them off the sketch and telling it what to do, I am curious to see if that was faster than doing it by hand. or maybe it is the "I tell it a list of instructions, go get coffee, come back and its done" type of improvement
Edited by SHCanada2
