JNicholas Posted November 8 Share Posted November 8 How do I set a default offset distance for doors so they always snap or measure 4 inches off a wall when placed? Thank you kindly for your feedback. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 8 Share Posted November 8 The only thing I know that will do that is the width of the casing. Link to comment Share on other sites More sharing options...
JNicholas Posted November 8 Author Share Posted November 8 @Joe_Carrick Thank you for your reply. Could be a good way to do it for now. I think there used to be a setting that would allow for a default door/wall offset - which would make place doors faster. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 8 Share Posted November 8 (edited) There are defaults for the number of trimmers and king studs. However, those have any effect on the placement of the door. The best we can do at this time is to use casing profiles that provide the width needed for the offset. Edited November 8 by Joe_Carrick Link to comment Share on other sites More sharing options...
Solution JNicholas Posted November 8 Author Solution Share Posted November 8 @Joe_CarrickIn case you're interested, here's a solution from Rene Rabbitt. Link to comment Share on other sites More sharing options...
para-CAD Posted November 8 Share Posted November 8 Your framers are going to want 3", 4-1/2", 6", or some other size so that they can just use 2x material. Four inches in the framing world is an odd thing. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted November 8 Share Posted November 8 Howdy J, I make sure the casing's width and reveal are close to what I want. Then I slam the door against the sidewall and use may arrow key to back away 1", which is may arrow key setting via grid snaps. Best Wishes! Charles Link to comment Share on other sites More sharing options...
JNicholas Posted November 8 Author Share Posted November 8 @para-CAD Thanks for the info! Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 8 Share Posted November 8 (edited) 14 minutes ago, JNicholas said: @Joe_CarrickIn case you're interested, here's a solution from Rene Rabbitt. Basically that's what I do, but then I immediately edit the casing width to what I actually want them to be. IAE, I've made a couple of suggestions in the Suggestions Forum. The more suggestions on this and "Door Stops" the better. Edited November 8 by Joe_Carrick Link to comment Share on other sites More sharing options...
DBCooper Posted November 8 Share Posted November 8 You can probably get what you want by mucking around with the casing width/reveal but at some point it might be easier to just place the window close and then set the exact position using your dimensions. Basically, there is no default setting that allows you to place a window or door an exact distance from a wall corner so you might want to send in a feature request for this: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Link to comment Share on other sites More sharing options...
Joe_Carrick Posted November 8 Share Posted November 8 4 minutes ago, DBCooper said: You can probably get what you want by mucking around with the casing width/reveal but at some point it might be easier to just place the window close and then set the exact position using your dimensions. Basically, there is no default setting that allows you to place a window or door an exact distance from a wall corner so you might want to send in a feature request for this: https://chieftalk.chiefarchitect.com/forum/8-suggestions/ Door and Window Offsets - Suggestions - ChiefTalk Forum Link to comment Share on other sites More sharing options...
megclay Posted November 12 Share Posted November 12 On 11/8/2026 at 12:12 PM, para-CAD said: Your framers are going to want 3", 4-1/2", 6", or some other size so that they can just use 2x material. Four inches in the framing world is an odd thing. Great suggestions so on a 6" spacing do you stack 4 2x4 together or add spacers Link to comment Share on other sites More sharing options...
para-CAD Posted November 13 Share Posted November 13 Depending on how many studs were on the job site, but also it might be useful to use blocking like three 12" to 16" scrap blocks nailed between two jack studs, creates a 4-1/2" jack "pack", then nailed to a king, and now you've got 6". Link to comment Share on other sites More sharing options...
