Default Door Offset Distance from Wall Corners
JNicholas
Go to solution Solved by JNicholas,
14 minutes ago, JNicholas said:
@Joe_CarrickIn case you're interested, here's a solution from Rene Rabbitt.  image.thumb.png.e19ce391015c66ce4d27f0729e746abe.png
Basically that's what I do, but then I immediately edit the casing width to what I actually want them to be.
IAE, I've made a couple of suggestions in the Suggestions Forum.  The more suggestions on this and "Door Stops" the better.
Edited by Joe_Carrick
You can probably get what you want by mucking around with the casing width/reveal but at some point it might be easier to just place the window close and then set the exact position using your dimensions.
Basically, there is no default setting that allows you to place a window or door an exact distance from a wall corner so you might want to send in a feature request for this:
https://chieftalk.chiefarchitect.com/forum/8-suggestions/
Door and Window Offsets - Suggestions - ChiefTalk Forum
