mtldesigns Posted November 3 Share Posted November 3 Curious, does this only work on actual exterior doors, because it doesn't seem to work on interior doors? On hall closets, or mechanical rooms (for example), I like to separate the trim packages so I don't have the high profile casings on the insides of these spaces. When I do this, 99.9% of the time it changes the exterior to a standard profile, when I want it the other way around. I was hoping that "reversing" the designation, that I could avoid having to fix both casings every time. Sure hope this made sense... Link to comment Share on other sites More sharing options...
CarrieS Posted November 3 Share Posted November 3 Looks like the "Reverse Interior/Exterior setting "Only available when a door symbol from the Library is specified as the Door Style." according to the Reference Manual. Are you using a Library door or a parametric door? Link to comment Share on other sites More sharing options...
mtldesigns Posted November 4 Author Share Posted November 4 3 hours ago, CarrieS said: Library door or a parametric door I am using the doors from my pull-down, so parametric. But those doors come from my set defaults, which contain doors from the library. I dropped a door from the library into this model, and the option to reverse isn't highlighted to pick. Link to comment Share on other sites More sharing options...
Renerabbitt Posted November 4 Share Posted November 4 On 11/2/2026 at 6:47 PM, mtldesigns said: because it doesn't seem to work on interior doors it does but you need this checked you could alternatively reverse layers of your interior wall 1 Link to comment Share on other sites More sharing options...
JiAngelo Posted November 5 Share Posted November 5 23 hours ago, Renerabbitt said: you could alternatively reverse layers of your interior wall Thanks for this. I was going crazy not being able to select exterior casings or lentils on some of my windows & doors that I'd copied from another plan. All the new ones I added were working just fine. I found all of them had that box unchecked. Thanks again. Link to comment Share on other sites More sharing options...
DBCooper Posted November 5 Share Posted November 5 If you copy a window or door from an exterior wall to an interior wall (or vice versa), you might also want to change the option for "interior door" or "exterior door". This is a new thing in X18 and in prior versions you couldn't change it. Link to comment Share on other sites More sharing options...
