winterdd Posted October 15 Share Posted October 15 (edited) Is there a way to modify my CA columns to match the pic below. Or how can we build custom ones that are not in the library? All I need to do is make the bottom part of the base taller. Thanks mine online Edited October 15 by winterdd Link to comment Share on other sites More sharing options...
joshuanyambisa Posted October 15 Share Posted October 15 Have you tried adjusting the base height in the column settings? If that isn’t possible, a custom molding profile may help achieve the desired look. Regards, Josh Link to comment Share on other sites More sharing options...
GeneDavis Posted October 15 Share Posted October 15 That's a solid question. There is a solid answer, and it's solids. Or Sketchup, or Blender. Link to comment Share on other sites More sharing options...
abrandner Posted 13 hours ago Share Posted 13 hours ago You can go into the item specs and put a stretch plane in where you want it to adjust. 1 Link to comment Share on other sites More sharing options...
para-CAD Posted 13 hours ago Share Posted 13 hours ago David Michael has columns like that. Link to comment Share on other sites More sharing options...
winterdd Posted 10 hours ago Author Share Posted 10 hours ago 3 hours ago, para-CAD said: David Michael has columns like that. Is that in the 3d library or a user on the forum? Link to comment Share on other sites More sharing options...
