SeaGlassHomes Posted July 27 Share Posted July 27 Hello All, What is the method everyone is using to get the openings to show screen? I know one way is to insert windows, minimize frame and remove casing. I have a screen porch that will have wrapped 6 x 6 posts and just full panel screens. So this instance the window route is probably not the way to go. Thanks. Link to comment Share on other sites More sharing options...
ericepv Posted July 27 Share Posted July 27 Try this... Specify your wall as a railing snd make the knewls 6x6 posts, for the rail, specify panels. I'm pretty sure there is a framed glass option in the Chief library that you can use or just make your own and then replace the glass with screen material. 1 Link to comment Share on other sites More sharing options...
Rosco2017 Posted Tuesday at 12:43 PM Share Posted Tuesday at 12:43 PM A great user by the name Steve Nester sells a screen porch library that I still use to this day on 90% of my projects. Check it out here. 1 Link to comment Share on other sites More sharing options...
CharlesVolz Posted Tuesday at 01:41 PM Share Posted Tuesday at 01:41 PM (edited) From my notes (no guarantees); Screened Porches: 1. Use Railing: Rail Style: Open, Post to Beam, Include Top & Bottom Rail; Rails: Top, Middle & Bottom. Insert Doors (CA will insert doorways, but change that to hinged door). For the screen material, use a molding polyline with a standard rectangular profile like CA-001 and make it the desired height and 1/16" thick with the material set to glass block or lattice (set to 1"x1"x1/16" >best) material which look better in 3D than the screen material. In X9+ you can combine Panels and Rails. Just make a simple Panel with Screen Material. Set the width & depth of the Beam in the “Rails” DBX (the Beam is one of the "Rails"). For more detailed work, use solids, p-solids, cabinets, moldings, slabs, framing material, etc. 2. Great videos by Steve Nestor (3). https://youtu.be/5QyskUt8UBQ, https://youtu.be/AB3Hjm1ZGwM, & https://youtu.be/VDNXmV056fo Lattice 3D (Creating in X18): 1. CTalk (Joe_Carrick): Use a 3D Molding. Here's one I did (2"x1/2" with 3" square holes. Rows set at 45 degrees. The 3D Molding I used was a cross of (2) 2"x5"x1/2" solids for 2" square holes use (2) 2"x4"x1/2" solids. By applying it to a wall with a 2" gap layer below, it will be pretty cool. It can also be used in a railing with top & bottom rails. FWIW, 3D Profiles using 3D Molding Symbols can result in a lot more surfaces and slow down the display. Each little cross in the Lattice has 12 surfaces so a 10'x30' wall with that 3D Profile will have over 20,000 surfaces. 2. CTalk (Steve_Nyhof): So this is a new way of adding lattice under a deck - lattice wall that makes a room - room floor is gravel - Air gap wall. When I run into it I will need to be mindful if things slow down - but typically there is not much lattice. Raise and lower the deck - I like this! 3. CTalk (Renerabbitt): Here is a method for 50 surfaces: YouTube Video Edited Tuesday at 02:51 PM by CharlesVolz Link to comment Share on other sites More sharing options...
SNestor Posted Wednesday at 05:02 PM Share Posted Wednesday at 05:02 PM Just get my library. It works great and it’s very inexpensive. 3 Link to comment Share on other sites More sharing options...
CliffsCris Posted Thursday at 09:39 PM Share Posted Thursday at 09:39 PM I use the method ericepv mentioned. Made my own screen panel. Recently had to also add cable railing and did that as a furred wall and overlapped it with the screen wall. Worked well. Railing is weird with doors though, so if I add a screen door, I have to insert my screen panel manually as millwork above the door and resize it to fit. Not too big of an issue, I just have to remember to move that panel if I relocate the door. I suppose I could make a panel that includes screen, a top rail, and cable if I remember. Link to comment Share on other sites More sharing options...
winterdd Posted Thursday at 11:49 PM Share Posted Thursday at 11:49 PM I use railing walls and turn off everything except the top and bottom handrails then manually build everything else. I use polyline solids for the screen and paint it with a screen texture. For the door I use a glass panel door and paint the glass with the same screen texture. 1 Link to comment Share on other sites More sharing options...
