Deck framing, once again, not showing
tbuck1db
make sure it's "deck framing",turned on, and not "floor framing" is my guess? I can't open the plan since I don't have Chief Premiere. Or if you changed anything, make sure that you have deck framing set to build again under the "deck" setting. What did you get for a solution when you asked this question the first time?
Edited by Rookie65
add words
I found a couple of problems:
1. Your deck room is marked as having a floor finish that looks like mahogany on top of foam.  Not sure if this was your intent, but if you check the "default" box it will go away.  If you want a wood floor on top of your deck, then you probably don't want to make it "framing".  If you don't want planks, then why is this room even a deck?  You might be better off making it a porch or something else?
2.  Your deck structure has planking that is marked as "joists" and it should be marked as "planking" instead.
3.  Your deck defaults are a bit messed up since your deck structure does not have any framing (joists).
"CHECK AUTOMATICALLY REGENERATE DECK FRAMING" IS CHECKED
i'VE CHANGED ALL OF THESE THINGS AND STILL CAN'T GET A STRUCTURE TO GENERATE. The settings also keep changing to other things, without me touching them.
