ACADuser Posted 17 hours ago Share Posted 17 hours ago Before I dive into this railing & the 6 or 7 other railings around this house I thought I would ask. To get a double top rail with balusters I would have to create a symbol or mill work for that? To get the decorative panes I would need to do the same? And I would need to break the railing wall into segments to place the decorative portion in that wall. Link to comment Share on other sites More sharing options...
JonathanK Posted 17 hours ago Share Posted 17 hours ago Could you find a good repeatable "breaking point" and just make one panel that includes the balusters and the custom panel? Then you don't have to try and break and do funkyness. Meaning...what if you make this section in red one panel. That's your repeat, set that as your custom panel and then it should work?... Link to comment Share on other sites More sharing options...
Renerabbitt Posted 16 hours ago Share Posted 16 hours ago 52 minutes ago, ACADuser said: I would need to do the same? This will handle that elevation, just delete any intermediate newels when you use it:Custom Railing For Allen.calibz 1 Link to comment Share on other sites More sharing options...
ACADuser Posted 11 hours ago Author Share Posted 11 hours ago I was able to get the main railing with the double top rail in another post. Tried you railing Rene but it did not come over correctly. Thanks for the gift though! Link to comment Share on other sites More sharing options...
Renerabbitt Posted 9 hours ago Share Posted 9 hours ago 2 hours ago, ACADuser said: I was able to get the main railing with the double top rail in another post. Tried you railing Rene but it did not come over correctly. Thanks for the gift though! Lol you used all the exact right combinations of render settings for that to not show up. Raster views it will show correct and vector elevation should show but may need the pattern offset and scale adjusted Link to comment Share on other sites More sharing options...
CharlesVolz Posted 9 hours ago Share Posted 9 hours ago 2 hours ago, ACADuser said: I was able to get the main railing with the double top rail in another post. Why don't you link that post here for others to benefit? Link to comment Share on other sites More sharing options...
