decorators3 Posted 9 hours ago Share Posted 9 hours ago I am attaching the PDF site plan,, Is this something I can import into chief and create ( only the darkened grey buildings ( I have the plans ) Cheers Levina new site plan1.pdf Link to comment Share on other sites More sharing options...
SHCanada2 Posted 8 hours ago Share Posted 8 hours ago (edited) you cam import pdfs and put them on their own layer. You can then scale and trace if you would like. it works best if there is a known dimension on the pdf Edited 8 hours ago by SHCanada2 Link to comment Share on other sites More sharing options...
decorators3 Posted 7 hours ago Author Share Posted 7 hours ago 36 minutes ago, SHCanada2 said: you cam import pdfs and put them on their own layer. You can then scale and trace if you would like. it works best if there is a known dimension on the pdf please excuse my limited knowledge - are there videos on scale and trace?.. also do you mean site plan dimensions? Link to comment Share on other sites More sharing options...
SHCanada2 Posted 6 hours ago Share Posted 6 hours ago I believe CA actually has a video. The simplest way to scale is: if there is a dimensions between two points on the pdf, you do a point to point measurement in CA (after you have imported the pdf), and then do a ratio of that measurement with the one on the PDF.. And then use the transform replicate to resize using that calculated ratio. in the simplest example: if there is a measurement on the pdf which says it is a 100m long parcel between tow parcel corners, but when you actually measure it in CA, CA shows it to be 50M, then you need to resize by a factor of 2 I also believe CA has a point to point resize tool that does the math for you. I seem to recall seeing it in their video, I just never remember where it is. It is probably in the help Link to comment Share on other sites More sharing options...
decorators3 Posted 5 hours ago Author Share Posted 5 hours ago 9 minutes ago, SHCanada2 said: I believe CA actually has a video. The simplest way to scale is: if there is a dimensions between two points on the pdf, you do a point to point measurement in CA (after you have imported the pdf), and then do a ratio of that measurement with the one on the PDF.. And then use the transform replicate to resize using that calculated ratio. in the simplest example: if there is a measurement on the pdf which says it is a 100m long parcel between tow parcel corners, but when you actually measure it in CA, CA shows it to be 50M, then you need to resize by a factor of 2 I also believe CA has a point to point resize tool that does the math for you. I seem to recall seeing it in their video, I just never remember where it is. It is probably in the help Sounds great I'm going to print this and keep in clients file.. Cheers Levina Link to comment Share on other sites More sharing options...
DBCooper Posted 5 hours ago Share Posted 5 hours ago This might be helpful too: https://www.chiefarchitect.com/support/article/KB-00018/importing-resizing-and-tracing-over-an-image-or-pdf-of-a-floor-plan.html#Resize Link to comment Share on other sites More sharing options...
mtldesigns Posted 2 hours ago Share Posted 2 hours ago 3 hours ago, SHCanada2 said: The simplest way to scale is: if there is a dimensions between two points on the pdf, you do a point to point measurement in CA (after you have imported the pdf), and then do a ratio of that measurement with the one on the PDF I do it this way as well. But I will try the suggestion that DB linked next time. @decorators3 You probably will need a contour map as well. The property details are nice, but that lot has a deep slope per Google Map. I am not sure on what you need to be doing, but if your designing, looks like having the contours will be a MUST! Link to comment Share on other sites More sharing options...
SHCanada2 Posted 28 minutes ago Share Posted 28 minutes ago one other tidbit. the highest amount of accuracy is achieved by doing the measurements on the longest straight line in the PDF that has a measurement printed Link to comment Share on other sites More sharing options...
