site plan
decorators3
I believe CA actually has a video.
The simplest way to scale is: if there is a dimensions between two points on the pdf, you do a point to point measurement in CA (after you have imported the pdf), and then do a ratio of that measurement with the one on the PDF.. And then use the transform replicate to resize using that calculated ratio. in the simplest example: if there is a measurement on the pdf which says it is a 100m long parcel between tow parcel corners, but when you actually measure it in CA, CA shows it to be 50M, then you need to resize by a factor of 2
I also believe CA has a point to point resize tool that does the math for you. I seem to recall seeing it in their video, I just never remember where it is. It is probably in the help
Sounds great I'm going to print this and keep in clients file.. Cheers Levina
I do it this way as well.  But I will try the suggestion that DB linked next time.
@decorators3
You probably will need a contour map as well.  The property details are nice, but that lot has a deep slope per Google Map.  I am not sure on what you need to be doing, but if your designing, looks like having the contours will be a MUST!
@decorators3
...how did you find that street
Your marks over the street names are a layer in the PDF so they can be moved or removed easily. I am sure your intention was for the marks to be permanent which means they should be embedded or "flattened" with the layer of the original pdf doc.
Ha ha..i was tryng to keep location private...such is life!..
