decorators3 Posted December 16, 2025 Share Posted December 16, 2025 Hi All I’m working on a house plan and could use some help with CAD details. I see several Roof Eave Detail options, but I’m not sure how to determine which one is the correct choice. I can easily tell which ones I don’t need, but I’m looking for guidance on selecting the right detail. I’m also wondering if there’s a standard wall section detail available, similar to the sample I’ve attached. This is my first time creating a full-scale house plan with complete CAD details, so any advice or best-practice recommendations would be greatly appreciated. Link to comment Share on other sites More sharing options...
Chrisb222 Posted December 16, 2025 Share Posted December 16, 2025 2 hours ago, decorators3 said: I’m not sure how to determine which one is the correct choice. A CAD detail is meant to convey to the reader how you're instructing that the subject matter is to be built. You don't "choose the correct one" unless it matches exactly how you want it constructed. Otherwise, you start with a camera view, or one of the supplied details that is close, and modify it to your specifications. Link to comment Share on other sites More sharing options...
decorators3 Posted December 16, 2025 Author Share Posted December 16, 2025 22 minutes ago, Chrisb222 said: A CAD detail is meant to convey to the reader how you're instructing that the subject matter is to be built. You don't "choose the correct one" unless it matches exactly how you want it constructed. Otherwise, you start with a camera view, or one of the supplied details that is close, and modify it to your specifications. ok got it Thanks Link to comment Share on other sites More sharing options...
winterdd Posted December 17, 2025 Share Posted December 17, 2025 (edited) On 12/16/2025 at 6:10 AM, decorators3 said: Hi All I’m working on a house plan and could use some help with CAD details. I see several Roof Eave Detail options, but I’m not sure how to determine which one is the correct choice. I can easily tell which ones I don’t need, but I’m looking for guidance on selecting the right detail. I’m also wondering if there’s a standard wall section detail available, similar to the sample I’ve attached. This is my first time creating a full-scale house plan with complete CAD details, so any advice or best-practice recommendations would be greatly appreciated. On each house I do, I cut a back clipped cross section of an exterior wall and detail it out from that view. Because footers, insulation, sheathing, studs, facade, pitch marks etc are very common on my homes, I have callouts saved in my library, plop them in and modify whatever text I need to. Little things like this and pre saved general notes really speed up designing plans. Edited December 17, 2025 by winterdd 1 Link to comment Share on other sites More sharing options...
Rookie65 Posted December 17, 2025 Share Posted December 17, 2025 Similar to Rob, I will do a section view through the whole structure. I have all of my section notes (roof, wall types, floor, foundation, etc) on a word document. Then I will copy and paste the appropriate one into a text box for the detail it applies too. I can change the wording as needed, and it makes for a very quick way to get the sections done. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted December 17, 2025 Share Posted December 17, 2025 (edited) I use a similar method. But I've stored my notes as Rich Text in my user Library. They are in folders by material type.so it's easy to find what I want and locate and add an arrow to point to the object. One of those Library notes actually retrieves the Object's Label - if it's cut in section like a framing member, etc. Edited December 17, 2025 by Joe_Carrick Link to comment Share on other sites More sharing options...
decorators3 Posted December 17, 2025 Author Share Posted December 17, 2025 41 minutes ago, winterdd said: On each house I do, I cut a back clipped cross section of an exterior wall and detail it out from that view. Because footers, insulation, sheathing, studs, facade, pitch marks etc are very common on my homes, I have callouts saved in my library, plop them in and modify whatever text I need to. Little things like this and pre saved general notes really speed up designing plans. These area all great solutions Thanks// Im learning.. Link to comment Share on other sites More sharing options...
bkjernis Posted 8 hours ago Share Posted 8 hours ago I am looking for a book on site plans to learn how to do site plans in chief architect. I am having trouble creating them. I would like to do site plans with a sloped lot and maybe some stairs going up to a balcony from a sub level. Link to comment Share on other sites More sharing options...
