EmpireDrafting Posted 4 hours ago Share Posted 4 hours ago I have built a terrain from survey information, but now when I am trying to manipulated to my proposed, the site will not move. Link to comment Share on other sites More sharing options...
Mark3D Posted 4 hours ago Share Posted 4 hours ago Upload your plan so we can see what is wrong Link to comment Share on other sites More sharing options...
DBCooper Posted 3 hours ago Share Posted 3 hours ago What and how are you changing things? Are you editing your elevation lines or are you trying to add new stuff? Lot's of different things you could be doing that can have different effects. Do you have auto rebuild terrain turned on? If not, then you will need to manually rebuild the terrain any time you make any changes. Link to comment Share on other sites More sharing options...
EmpireDrafting Posted 3 hours ago Author Share Posted 3 hours ago (edited) I AM USING X17 I AM TRYING TO ADD ADDITIONAL ELEVATION PLANES ASIDE FROM THE ELEVATION DATA THAT CAME IN FROM THE SURVEY. UNFORTUNATELY MY FILE IS TO BIG TO UPLOAD Edited 2 hours ago by EmpireDrafting Link to comment Share on other sites More sharing options...
SHCanada2 Posted 1 hour ago Share Posted 1 hour ago what happens when you add an elevation region? or how exactly are you "trying to add"? Link to comment Share on other sites More sharing options...
