EmpireDrafting Posted November 6, 2025 Share Posted November 6, 2025 I have built a terrain from survey information, but now when I am trying to manipulated to my proposed, the site will not move. Link to comment Share on other sites More sharing options...
Mark3D Posted November 6, 2025 Share Posted November 6, 2025 Upload your plan so we can see what is wrong Link to comment Share on other sites More sharing options...
DBCooper Posted November 6, 2025 Share Posted November 6, 2025 What and how are you changing things? Are you editing your elevation lines or are you trying to add new stuff? Lot's of different things you could be doing that can have different effects. Do you have auto rebuild terrain turned on? If not, then you will need to manually rebuild the terrain any time you make any changes. Link to comment Share on other sites More sharing options...
EmpireDrafting Posted November 6, 2025 Author Share Posted November 6, 2025 (edited) I AM USING X17 I AM TRYING TO ADD ADDITIONAL ELEVATION PLANES ASIDE FROM THE ELEVATION DATA THAT CAME IN FROM THE SURVEY. UNFORTUNATELY MY FILE IS TO BIG TO UPLOAD Edited November 6, 2025 by EmpireDrafting Link to comment Share on other sites More sharing options...
SHCanada2 Posted November 6, 2025 Share Posted November 6, 2025 what happens when you add an elevation region? or how exactly are you "trying to add"? Link to comment Share on other sites More sharing options...
scottharris Posted November 7, 2025 Share Posted November 7, 2025 If you have a place you can upload the plan, send a link. With Terrain, you do not want over lapping terrain data. So, when you add new terrain, you may need to remove existing terrain elevation information. Link to comment Share on other sites More sharing options...
