Label Fill Option
Adam_Gibson
Does anyone have a quick workaround for adding fill to labels? For example, I want filled beam labels so the joists that rest on the beams do not obscure the labels. I suppose I could create a text block, but that gets old pretty quickly. Seems like that should be an option for all label styles, since other items inherently have fill (cabinets, windows, etc.).
Edited by Adam_Gibson
I *think* all object labels are filled or not filled based on the text style used for the label.  Try turning off "transparent" for the text style to see if this gives you what you want.
Framing label that has text style with "transparent" unchecked and "border" turned on:
Edited by DBCooper
Robert is correct that you can't get the beam label to display on top of the joists since the beam is under the joists.  Labels always display in the same drawing level that the owner object displays.  You could rotate it 90 degrees but TBH I would probably just create manual text for this case.
Your picture still looks like your beam label is transparent though. Not sure how you are getting that if you unchecked "transparent" for the label text style.
17 hours ago, Adam_Gibson said:
As much as I appreciate the time and energy to help me, this is not the solution as it does not block out what's behind the text, which is my goal. But I thank you for trying!
I feel your pain, I lightened up the line thicknesses and made the floor joist fill colour more transparent, while making the bearing beam label text dark and bold. It's not ideal but it got me closer to desired end result. I also make the beam appear 'different' from a solid item like a wall - dashed lines with white fill.
Hope this helps until CA makes it change.
