Import File From Magicplan
derek884
I use magic plan on my ipad to create a layout because it is super easy. I would like to import this layout into Home Designer Suite 2016. MagicPlan exports into a dxf file. It doesn't look like HD has any good option of importing layout. I do not see a dxf option.
Is my only option to recreate it?
  • 6 years later...
HD PRO users can benefit from following ChiefTalk as PRO has many manual features like Chief Premier has
Just understand PRO's limits and if you post on Chieftalk please clarify that you are using PRO
and that some of the suggestions may not apply to PRO
Lew
Lew
In this particular case Lew it makes a large difference as unless it came out with the newest version of HDP They do not have the convert polyline to walls tool so they really should post this question in the other forum to get the best advice.
