ericepv Posted April 3, 2015 Share Posted April 3, 2015 I am trying to create a railing that sits on to of the support wall next to the stairway (see photos) rather than on the stair treads. I have tried using a half wall (as a railing) and also a full wal (as in the attached plan) but can't get the rail on top of the wall which follows the slope of the stairs. I also am getting an opening in the ceiling surface above the stair support wall. Link to comment Share on other sites More sharing options...
ericepv Posted April 3, 2015 Author Share Posted April 3, 2015 Forgot to attach the plan file, here it is. 74 Master-X7-rev.zip Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 3, 2015 Share Posted April 3, 2015 Take an elevation view. Draw polyline solid with a slope matching the stairs and move into position. Do another for the wall cap with the desired thickness, say 1" and change material as needed. There may be another method but it eludes me at the moment. Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 3, 2015 Share Posted April 3, 2015 Here is a video of the process. https://www.youtube.com/watch?v=LhPc-Vtx73w Link to comment Share on other sites More sharing options...
jcaffee Posted April 3, 2015 Share Posted April 3, 2015 Scott did this vid as well https://www.youtube.com/watch?v=Lotf8hBM93E jon Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted April 3, 2015 Share Posted April 3, 2015 I was looking for that! Link to comment Share on other sites More sharing options...
ericepv Posted April 4, 2015 Author Share Posted April 4, 2015 jcaffee - That video did the trick, it was easy but now I have a second newel post in the midle of the rail that showed up after I dragged out the length of the ramp to match my stair uonit. . Any idea of how to gid rid of it? Link to comment Share on other sites More sharing options...
jcaffee Posted April 4, 2015 Share Posted April 4, 2015 Post the plan. I don't do twenty questions. jon Link to comment Share on other sites More sharing options...
ericepv Posted April 4, 2015 Author Share Posted April 4, 2015 Here's the latest plan. 74 Master-X7-rev.zip Link to comment Share on other sites More sharing options...
ACADuser Posted April 4, 2015 Share Posted April 4, 2015 Plan in Zip file is 0 bites. You should be able to set the distance between Newel Post in the dialog. Link to comment Share on other sites More sharing options...
ericepv Posted April 5, 2015 Author Share Posted April 5, 2015 I did not see anything in the dialog regarding distance between the Newel Posts. Here's another try at the plan. 74 Master-X7-rev.zip Link to comment Share on other sites More sharing options...
jcaffee Posted April 5, 2015 Share Posted April 5, 2015 Have a look with what I did to the rail on the ramp. If you need the newels in plan view, the set newels to zero in the dbx and place them manually. jon 74 Master-X7-rev_JCC_Edit.zip Link to comment Share on other sites More sharing options...
Solution Bill_Emery Posted April 5, 2015 Solution Share Posted April 5, 2015 Here's a different take on the railing over a wall. It's done entirely with live walls, and live railings. The method here is to use a double stair. The stair is copied in place, and then made wider so the copied railing will come up thought the wall, while the original stairway remains in place to show the stringers. The walls are adjusted in elevation, and then slid into place under the railing. The method with the railing is to stay just shy of centered under the wall, or the stairs will cut the wall. Having live walls allows the framing to be correct, and having live railings allows me change newel, baluster, and railing stiles easily. It also allows me to easily edit the run and rise of the stairs as necessary. I've not shown it here, but this method also allows the stair railing to connect with a mezzanine railing above. The wider stairs that are used to show the railings are set to "back group" so they don't appear to cover the wall layers in plan view. I've attached the plan if anyone wants to have a look. Live stairs 5.plan Link to comment Share on other sites More sharing options...
DRAWZILLA Posted April 5, 2015 Share Posted April 5, 2015 You guys thinking O.O.T.Box is great. Link to comment Share on other sites More sharing options...
ericepv Posted April 6, 2015 Author Share Posted April 6, 2015 Thanks to everyone for your ideas. Bill, yours did what I needed. Link to comment Share on other sites More sharing options...
Charlie Posted September 15, 2015 Share Posted September 15, 2015 That works really well, Bill. Link to comment Share on other sites More sharing options...
