jtcapa1 Posted Wednesday at 11:08 PM Share Posted Wednesday at 11:08 PM Like many of you, I've been taking advantage of CA's growing ability to accurately display building elements in 3d, and have moved away from Textures when I need that extra detail in a 3d rendering. I'm wondering if there are any simpler ways to achieve this look of a standing seam roof without inserting 3d models from sketchup, stretch them, rotate, space, rinse and repeat. This looks great, but takes far to much time. Link to comment Share on other sites More sharing options...
GeneDavis Posted yesterday at 01:08 AM Share Posted yesterday at 01:08 AM First thing I though of was hey would't it be good if we had a way to do material regions on roof planes. But that would be tedious for all the houses with more, maybe a lot more, then two or four planes. They there would be the need for properly raised hip and ridge caps, and a way to properly do valleys, holding the roof ribs back from the valley lines. So I though, OK, Revit must certainly be able to 3D model standing seam. But this video suggests no, because it is by a Revit user doing it with a workaround that uses Revit's "greenhouse roofs" tools. Link to comment Share on other sites More sharing options...
Rookie65 Posted yesterday at 01:14 AM Share Posted yesterday at 01:14 AM Is it not in the chief library? Home Designer Pro has it Link to comment Share on other sites More sharing options...
JKEdmo Posted 23 hours ago Share Posted 23 hours ago (edited) Try messing around with a distribution region. It can in fact be set so that the elevation references a roof plane. Here I drew the region across my roof in plan: I defined a skinny box to be distributed 18" o.c. This will act as the standing seam. Here's the part that makes the region match the roof plane: Here's the result below in 3D. Note that the 3D distribution region objects are the white "slats." (The dark grey standing seam is just standard material texture. I happened to be working on a SS roof at the time). First time I tried this, but I think the Distribution Region could be finessed to make this work. Jim P.S. Doing this in X17. Edited 23 hours ago by JKEdmo Clarification Link to comment Share on other sites More sharing options...
