Joe_Carrick Posted March 21, 2014 Share Posted March 21, 2014 In order to have a half open Pocket Door in 3D: 1. Use a Door Symbol with the x origin offset 1/2 of the Door Width. 2. You need to copy the desired door to your User Library, open it and adjust the x origin. 3. Now, insert that Door in the Wall and make it a "Pocket Door". 1 Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted March 21, 2014 Share Posted March 21, 2014 Good tip! Link to comment Share on other sites More sharing options...
GeneDavis Posted March 21, 2014 Share Posted March 21, 2014 And be sure, as Joe did, to put your hardware on the door symbol. If you don't, the only way to get hardware is with the standard Chief spec dialog, and you won't like the results. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 21, 2014 Author Share Posted March 21, 2014 Gene, The Chief Spec Dialog will not add hardware to Pocket Doors at all. I uploaded a copy of my sliding door symbol in another thread with the hardware. I do have my development dwg saved so I can create other Pocket Doors. Link to comment Share on other sites More sharing options...
CJSpud Posted March 21, 2014 Share Posted March 21, 2014 Joe: What does the plan view look like? Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 22, 2014 Author Share Posted March 22, 2014 Joe: What does the plan view look like? Same as Chief's default Pocket Door. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 22, 2014 Author Share Posted March 22, 2014 I'm working on a set of Pocket Door Symbols with Pulls. Here's an example of the 3 doors I've done so far. 1. Single Panel (Shaker style - closed and open) 2. Double Panel (Shaker style - closed and open) 3. Slab (closed and open) I also want to do Single and Double Raised Panel and Single and Double Glass Panel. Does anyone have any other desired styles? Should the open Doors be more or less open? Currently they are 1/2 open but I could make them more or less. Link to comment Share on other sites More sharing options...
CJSpud Posted March 22, 2014 Share Posted March 22, 2014 Joe: Thanks ... I assumed that is what you meant confirmed after rereading your 1st post. It is hard to understand why we don't have the option to show the door in the half-open position like the symbol shows in plan. I have customers that like the 4 and 6 panel standard door styles and I occasionally get requests for Sante Fe styled doors with the broken arch in the top panel frame. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 22, 2014 Author Share Posted March 22, 2014 Cliff, I'll work on those as well. Currently I'm up to the point where all the materials are editable (Stiles, Rails, Upper and Lower Panels) and I've also included offsets of y=5 & y=-5 to accommodate "Barn Sliding" but I need to generate 2D Blocks and symbols for the Surface Pocket Tracks. This will be a Library of over 40 Symbols before I'm done. It's a kludge vs a software fix, but IMO it's safer to do it this way. I don't have a lot of faith that CA would get it right in software. ;) Link to comment Share on other sites More sharing options...
Dennis_Gavin Posted March 23, 2014 Share Posted March 23, 2014 Joe - I also use mostly 6 panel doors. I think half open is as good as any other option. Besides we can always change to origin as you pointed out previously. Very generous of you to do this. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 23, 2014 Author Share Posted March 23, 2014 The Library is located at https://chieftalk.chiefarchitect.com/index.php?/topic/484-pocket-surface-sliding-door-library/ Link to comment Share on other sites More sharing options...
raltd9245 Posted March 24, 2014 Share Posted March 24, 2014 In order to have a half open Pocket Door in 3D: 1. Use a Door Symbol with the x origin offset 1/2 of the Door Width. 2. You need to copy the desired door to your User Library, open it and adjust the x origin. 3. Now, insert that Door in the Wall and make it a "Pocket Door". JOE, The offset has me baffled. I'm just a stupid ole man as the troll says. Link to comment Share on other sites More sharing options...
Joe_Carrick Posted March 25, 2014 Author Share Posted March 25, 2014 JOE, The offset has me baffled. I'm just a stupid ole man as the troll says. Open the Door Symbol in the Library. On the General Tab set the x-origin to 15" (1/2 of the width of a 30" door). This will move the 3D symbol so that it's 15" away from the strike side. When you place that Door as a Pocket Door it will appear half open. You can download theLibrary that I posted - it has symbols for "Closed, 18" Open & 26" Open". Note that when you place one of these in a wall it will be "Hinged" which is of course not what you want so just change the Type to "Pocket". Link to comment Share on other sites More sharing options...
