JKEdmo Posted Tuesday at 12:15 AM Share Posted Tuesday at 12:15 AM Another forum discussion touched on plans (layout boxes) aligning exactly from page to page. To achieve this I currently just copy/paste/hold position my layout box to the new sheet and update the view. But, can somebody explain to me how the other "Snap to Active CAD Point" method works in order to get exact positioning (or point me to a video)? I tried this but couldn't quite figure it out. I figure it's time I learned. Thanks, Jim Link to comment Share on other sites More sharing options...
Joe_Carrick Posted Tuesday at 12:37 AM Share Posted Tuesday at 12:37 AM I just make a cad rectangle that matches the sheet size. I display the sheet boundary to get it right. Then when I send to layout - full sheet all my plan views are perfectly aligned. Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 12:59 AM Author Share Posted Tuesday at 12:59 AM This is how I understood the procedure after reading the help file: In my PLAN view, I place a temporary point as an alignment reference: On my layout sheet, I place another temporary point as the destination reference point... When I send to layout, the layout box will align at those two points. Is this correct? Jim Link to comment Share on other sites More sharing options...
Solution Eric_S Posted Tuesday at 01:10 AM Solution Share Posted Tuesday at 01:10 AM 6 minutes ago, JKEdmo said: When I send to layout, the layout box will align at those two points. Is this correct? Hello Jim, With this option, the layout box is placed on the page so that the CAD point sits on the left side of the box, centered vertically. CAD points placed in Plan do not affect this. This is clearer when you select the layout box: Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 01:36 AM Author Share Posted Tuesday at 01:36 AM 25 minutes ago, Eric_S said: Hello Jim, With this option, the layout box is placed on the page so that the CAD point sits on the left side of the box, centered vertically. CAD points placed in Plan do not affect this. This is clearer when you select the layout box: Thanks Eric for clarifying. Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted Tuesday at 01:47 AM Author Share Posted Tuesday at 01:47 AM 1 hour ago, Joe_Carrick said: I just make a cad rectangle that matches the sheet size. I display the sheet boundary to get it right. Then when I send to layout - full sheet all my plan views are perfectly aligned. Thanks for the good tip. Jim Link to comment Share on other sites More sharing options...
SHCanada2 Posted Tuesday at 02:08 AM Share Posted Tuesday at 02:08 AM and for those of us who rarely every send to layout...is there a method? Link to comment Share on other sites More sharing options...
MoeGia Posted yesterday at 11:49 AM Share Posted yesterday at 11:49 AM Once I have a view positioned where I want it, I place a point at a corner of the plan or floor line for an elevation. Then use point to point to position the others in the same location. Link to comment Share on other sites More sharing options...
SHCanada2 Posted 21 hours ago Share Posted 21 hours ago 4 hours ago, MoeGia said: Once I have a view positioned where I want it, I place a point at a corner of the plan or floor line for an elevation. Then use point to point to position the others in the same location. hmmm not sure I understand, can you elaborate? i.e. are you doing this on top of the layout box? Link to comment Share on other sites More sharing options...
MoeGia Posted 2 hours ago Share Posted 2 hours ago I have everything pre-sent to layout, but I often have to move things around. Let's say I'm trying to align a plan with an elevation like your plot plan and elevation cut example. In that case I would place a vertical line and use point to point by going into the veiwport and picking the edge of the elevation I want lined up and moving it to the line. I would then do the same for the other elevation. Then delete the line. Link to comment Share on other sites More sharing options...
