JKEdmo Posted April 1, 2025 Share Posted April 1, 2025 Another forum discussion touched on plans (layout boxes) aligning exactly from page to page. To achieve this I currently just copy/paste/hold position my layout box to the new sheet and update the view. But, can somebody explain to me how the other "Snap to Active CAD Point" method works in order to get exact positioning (or point me to a video)? I tried this but couldn't quite figure it out. I figure it's time I learned. Thanks, Jim Link to comment Share on other sites More sharing options...
Joe_Carrick Posted April 1, 2025 Share Posted April 1, 2025 I just make a cad rectangle that matches the sheet size. I display the sheet boundary to get it right. Then when I send to layout - full sheet all my plan views are perfectly aligned. Link to comment Share on other sites More sharing options...
JKEdmo Posted April 1, 2025 Author Share Posted April 1, 2025 This is how I understood the procedure after reading the help file: In my PLAN view, I place a temporary point as an alignment reference: On my layout sheet, I place another temporary point as the destination reference point... When I send to layout, the layout box will align at those two points. Is this correct? Jim Link to comment Share on other sites More sharing options...
Solution Eric_S Posted April 1, 2025 Solution Share Posted April 1, 2025 6 minutes ago, JKEdmo said: When I send to layout, the layout box will align at those two points. Is this correct? Hello Jim, With this option, the layout box is placed on the page so that the CAD point sits on the left side of the box, centered vertically. CAD points placed in Plan do not affect this. This is clearer when you select the layout box: Link to comment Share on other sites More sharing options...
JKEdmo Posted April 1, 2025 Author Share Posted April 1, 2025 25 minutes ago, Eric_S said: Hello Jim, With this option, the layout box is placed on the page so that the CAD point sits on the left side of the box, centered vertically. CAD points placed in Plan do not affect this. This is clearer when you select the layout box: Thanks Eric for clarifying. Jim Link to comment Share on other sites More sharing options...
JKEdmo Posted April 1, 2025 Author Share Posted April 1, 2025 1 hour ago, Joe_Carrick said: I just make a cad rectangle that matches the sheet size. I display the sheet boundary to get it right. Then when I send to layout - full sheet all my plan views are perfectly aligned. Thanks for the good tip. Jim Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 1, 2025 Share Posted April 1, 2025 and for those of us who rarely every send to layout...is there a method? Link to comment Share on other sites More sharing options...
MoeGia Posted April 3, 2025 Share Posted April 3, 2025 Once I have a view positioned where I want it, I place a point at a corner of the plan or floor line for an elevation. Then use point to point to position the others in the same location. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 3, 2025 Share Posted April 3, 2025 4 hours ago, MoeGia said: Once I have a view positioned where I want it, I place a point at a corner of the plan or floor line for an elevation. Then use point to point to position the others in the same location. hmmm not sure I understand, can you elaborate? i.e. are you doing this on top of the layout box? Link to comment Share on other sites More sharing options...
MoeGia Posted April 4, 2025 Share Posted April 4, 2025 I have everything pre-sent to layout, but I often have to move things around. Let's say I'm trying to align a plan with an elevation like your plot plan and elevation cut example. In that case I would place a vertical line and use point to point by going into the veiwport and picking the edge of the elevation I want lined up and moving it to the line. I would then do the same for the other elevation. Then delete the line. Link to comment Share on other sites More sharing options...
SHCanada2 Posted April 4, 2025 Share Posted April 4, 2025 ok thanks, yes that is what do as well, although a lot of times I will just use the cross hairs and get it close enough, for layout boxes on the same layout I tried once to have a few different lines on the layout(on a layer I turned on and off on layout) for bungalows vs 2 storeys to align elevations, but ended up moving them around anyway. It is almost like a numbered grid would be useful on layout in absence of being able to snap to walls within the layout box 1 Link to comment Share on other sites More sharing options...
