JKEdmo Posted March 12 Share Posted March 12 Trying to add a custom muntin pattern to an arched window... I drew the linework, blocked it, but when I load it as a custom muntin pattern into the window, the muntins go a little crazy and extend too far. Any tips in getting this to play nice? I suspect there might be some rules of thumb / best practices to drawing the line work "just right" for the muntin tool. Blocked line work (before): Custom muntin result (after): Thanks again, Jim Link to comment Share on other sites More sharing options...
robdyck Posted March 12 Share Posted March 12 Jim, try pulling the bottom of the radial lines back about 1/4" from the lower arch. Link to comment Share on other sites More sharing options...
JKEdmo Posted March 12 Author Share Posted March 12 24 minutes ago, robdyck said: Jim, try pulling the bottom of the radial lines back about 1/4" from the lower arch. Thanks Rob. I'm stumped. Tried your suggestion. Even tried getting rid of the lower arch and turning it into a segmented line. The rays still shoot through. I might still fiddle with it Link to comment Share on other sites More sharing options...
GeneDavis Posted March 12 Share Posted March 12 Try extending the radials an inch or so outside. The top ends. Link to comment Share on other sites More sharing options...
robdyck Posted March 12 Share Posted March 12 @JKEdmo Try this cad block. Explode and edit and also take a look at how it's made and see if it works for you. The arch polylines have 30 segments and I reversed the start / end of the middle radial.archlite.calibz Link to comment Share on other sites More sharing options...
JKEdmo Posted March 12 Author Share Posted March 12 Thanks Rob and Gene for your input and work. OK, I think I figured out the problem or at least a workaround. My original arched window was a true arch - 6' wide by 3' tall. Robert, here's that window with your custom muntin block applied. However, same problem as before. But, as soon as I add 1/8" to the window height (36.125"), it works. So, my theory -- at least for now -- is adding a bit of straight sides to the bottom of the window seems to help the muntin tool figure things out... Jim Link to comment Share on other sites More sharing options...
DBCooper Posted March 13 Share Posted March 13 Just an FYI, you don't actually need custom muntins to make that window. 1 Link to comment Share on other sites More sharing options...
JKEdmo Posted March 13 Author Share Posted March 13 40 minutes ago, DBCooper said: Just an FYI Thanks for the tip - Jim Link to comment Share on other sites More sharing options...
