Crown molding to follow vaulted ceiling
TennVol
To remove the molding from just one wall, open the DBX for the wall and in the 'General' tab, check 'No Room Moldings Interior/Exterior'. To get the crown to follow the vault, until Chief adds that option, you'll have to draw it as a polyline and convert it to a molding.
Actually, it's pretty easy to do this.  Just select the room with the crown molding and use the "make room molding polyline tool".  This tool will convert the automatic room molding into a custom molding so that you don't have to draw it yourself.  Then make an elevation view looking at the wall with the vault.  All you need to do is add a beak point in the middle and just drag it up to the peak.
  • Like 2
As a designer that is in the field weekly visiting our job sites, I can tell you 100% that the trim carpenters will be telling stories about the jerk designer that thought it was cool putting crown molding on a vaulted ceiling. I am one of those designers....sadly....I don't do that any longer.
