HumbleChief Posted February 13 Share Posted February 13 Seems pretty straight forward 1. Cut hole in the floor (since it's not technically a roof plane); 2. Grab skylight from the library and voila? Hole's no problem but can't for the life of me find a 'skylight' in the library. Is there another/better technique? Link to comment Share on other sites More sharing options...
scottharris Posted February 13 Share Posted February 13 Larry, if you cannot find the specific shaped skylight in the chief library (search 'skylights'), you can make your own (3D solids, then convert to symbol). Link to comment Share on other sites More sharing options...
GregoryStorm Posted February 14 Share Posted February 14 I've added skylights to projects but not from the Library. The skylights I used were located by clicking the Roof Palette. Then you have control over the material for frame, glass, and shaft. You can also dial in the exact dimensions you need as well as select from square or plumb sides. Link to comment Share on other sites More sharing options...
Gawdzira Posted February 14 Share Posted February 14 Make a flat roof (new file) and place a skylight the size that you want. Then save it out as a symbol for import as an object for your usage. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 14 Author Share Posted February 14 17 hours ago, scottharris said: Larry, if you cannot find the specific shaped skylight in the chief library (search 'skylights'), you can make your own (3D solids, then convert to symbol). Thanks Scott but can't find any 'skylight' or 'skylights' in the library. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 14 Author Share Posted February 14 16 hours ago, GregoryStorm said: I've added skylights to projects but not from the Library. The skylights I used were located by clicking the Roof Palette. Then you have control over the material for frame, glass, and shaft. You can also dial in the exact dimensions you need as well as select from square or plumb sides. Thanks Gregory but in this case it's actually a 'floor', not a 'roof'. Link to comment Share on other sites More sharing options...
HumbleChief Posted February 14 Author Share Posted February 14 16 hours ago, Gawdzira said: Make a flat roof (new file) and place a skylight the size that you want. Then save it out as a symbol for import as an object for your usage. Thanks, that might work Alan. I'll give it a try. Link to comment Share on other sites More sharing options...
JKEdmo Posted February 14 Share Posted February 14 20 minutes ago, HumbleChief said: Thanks Scott but can't find any 'skylight' or 'skylights' in the library. Larry, You might need to download the Bonus Catalog / Exterior Roof Attachments: Jim 1 Link to comment Share on other sites More sharing options...
HumbleChief Posted February 14 Author Share Posted February 14 11 minutes ago, JKEdmo said: Larry, You might need to download the Bonus Catalog / Exterior Roof Attachments: Jim Thanks Jim, did not know of that library. Link to comment Share on other sites More sharing options...
